Clicking noise when turning.
JLSpartan
JLSpartan
Roman
Michigan
18 JL Sport
Just a quick update after driving around for a month or so after my dealer appointment. They told me they checked everything but couldn't hear the noise, went to pick it up really excited to prove them wrong but the noise was gone.
I did let them know about tightening the bolts as you all discussed and I'm pretty sure they probably did but didn't want to admit anything.
So far so good!
HRDRCK
Tashsa
St. Louis
2016 rubicon hard rock
Dental professional
Hi all I've been noticing a clicking noise that seems to be coming from the from driver side wheel well only when I turn right.
Unless it also happens when I turn right and I'm just not hearing it.
Has anyone experienced this? I'm probably going to take it into the dealer, feel like something isn't tightened and hoping it's not u joint already going bad.
So happy I finally found something about this, I have been searching for “popping sound driver side” at first I thought it was my seat but definitely not the seat and get worse as time goes on. It doesn’t seem to just be when turning like before, a quicker stop will do it too.
Mercury191
Phillip
NB Canada
Wrangler JL Rubicom unlimited
800km on my JL rubicon with 37s,, and the clicking has begin, as im reading this treat im gonna buy myself a good torque wrench and some cotter pins this weekend.
Tanks for the info yall
mgroeger
Southern UT
2021 JLUR 2.0T
I wouldn't sweat the torque wrench. They are saying 33 ft/lbs for the lower ball joint nuts and I can tell you from first hand experience you need to go way past that.
Command Line RC
Cleveland OH
2018 Jeep JL Wrangler Unlimited
I was finally able to remove the cotter pins and tighten down the upper and lower ball joints.
History: I went to the dealership and asked them to please inspect/tighten the upper and lower ball joints due to the said "clicking" sound. After a half an hour waiting at the dealership, they stated that the clicking was due to the lift kit I installed.
Not happy about their answer because I knew every nut and bolt that was on the lift kit..and I know I tightened everything to spec.
Friday, I took both wheels off in the driveway and removed the cotter pins. I could hand loosen the upper's and semi hand loosen the bottoms.
I tightened them all and installed new cotter pins.
Not only has the clicking gone away, the "loose" handling while driving the interstate is 100% gone. Why on earth are so many ball joints loose for Jeepers. Needless to say I'll be contacting the service department manager to explain the situation.
Hope this helps someone on here!
Jeepsterfreak
Honda, Future JLU
You should file a complaint with the NHTSA. This problem seems widespread and a possible safety issue. Maybe it will force a recall.
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Mercury191
Phillip
NB Canada
I have tighten the 4 balljoint nuts,. Keeps clicking,.
I have tighten them again this morning to the second slots on the nut for the cotterpin to go true, and still clicking when turning.. i am calling the dealership tomorrow. It is sad to pay so much money for a vehicle and have problem at under 1k . Did you guys tighten more than two slots? I dont want to strip the treads it seems really tight. Tanks
saltyaggie
S. TX
2018 JLUS
JLUS here with no clicking noises, but after reading some of these posts I decided to check my lower BJ's. They were nowhere near 33 ft lbs, I went one notch tighter on both. I'll be checking the uppers soon.
Command Line RC
Cleveland OH
I saw the foot pounds that they were supposed to be torqued to and that is nowhere near enough in my opinion. I tighten them down really hard. with that being said I'm curious to see what your dealership says.
mgroeger
Southern UT
2021 JLUR 2.0T
Ditto, 33lbs no where close.
GlockJeeper
KY
2022 JLU Willys
Went to the dealership today, all 4 (upper & lower) ball joint’s nuts were tightened and new cotter pins installed. Clicking is now gone and I’m a happy camper.
Elganja
Virginia
2018 Bright White JLUR, 2015 Dodge Viper GT, 2014 Audi R8 V10, 2015 Audi S3
mine certainly clicks in 4 low-- but that is it
i'll have the dealer check the ball joints just in case... i figured it was normal for 4 low
Wfd1244
Shawn
Wichita Kansas
2018 JL wrangler unlimited sport s
Jeep Wrangler JL Clicking noise when turning. 8DD4640C-0A11-4938-9AD6-8AAB8931B433
Jeep Wrangler JL Clicking noise when turning. B37410FF-CA2A-4E05-B4A9-FBEC199CBCC8
Hello to all again. I just got my Jeep back from the dealer. I posted a video to the thread earlier about how I attempted to tighten my own ball joints, but I was nervous to really crank down on them, and after some time, a clicking noise would pop up for a click every once in a while. So I ended up caving and taking it to the dealer.
Here are the results: they replaced all four front ball joints. The tech said potentially by not having them tightened, they were prone to premature wear, and the best course of action to prevent replacement in the future (which would be at my cost if its out of warranty) was to just replace them. He said the ball joints when ordered from the factory came in a package with an upper and lower together with castle nuts and cotter pins, so he ordered two sets and installed them today. He also said he tightened them down a little more than Spec, so to prevent the new ball joints from clicking.
I have included a picture of my work order as well as the ball joint installation instructions my technician recieved, so you guys can show these to your service agents if they try to rebutle your problem with the excuse “it’s a jeep thing.”
