ejewels
hey man I’m thinking of the ride rite 1.5” kit they sell. I can always upgrade later to overland. Anyways, I’m in a 2021 JLU Willy’s with the Rubi shocks and sport springs. I understand this kit gives non-rubicons more like 2-2.5” of lift? I’m sticking with 33s so don’t want too much lift. Also, what size fox shocks? The kit says 1.5” lift but Insaw you said 2-3” versions?Looks great! it will settle a bit more and then if you have steel bumper and winch in the plan, then you are better off keeping the 1/2" pucks.
Part of the reason why you have the feeling that you got more lift is because you also moved to the high clearance rubicon fender (I didnt do that). I have the same lift with fox shocks, I added the 1/2" teraflex spacers on all 4 corners. The front needed it and was evident after bumper+winch - I lost about 1/2" of clearance. I contemplated removing them on the rear, but when im fully loaded for camping, I dont have the reverse rake and it stays level. I loved that, so hence left all the spacers in there. When not loaded the forward rake is a good thing and helps with on-road (as intended from factory).
Note: For others considering this lift, I highly recommend the FOX 2.0 shocks (2-3" lift version). This shock's travel and valving is the perfect pairing to the high spring rate of Clayton - giving you a firm ride yet soaks up small bumps and corrugated roads. Falcons are great but they are firmer than the FOX shocks even at their soft setting. Bilstein 5100s are good shocks but the additional 400-ish spent on FOX will definitely help with the ride quality.
