CB RADIO QUESTION
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hey guys/gals
im new to the cb radio work -kinda...
can one communicate nationwide ? state wide ?
im thinking ahead , " in case cell towers/phones are not available, can one communicate very ling distances with a CB Radio ?
Cheers
ZeoBandit
Illinois
2024 Wrangler Sport S
CB radios have a range of maybe three miles, depending on topography.
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
CB range varies with atmospheric conditions. Years ago I had a Galaxy SSB CB radio and I could ALWAYS talk across 5 miles or so in normal terrain (not so much in the mtns) but on rare occasions I talked to guys on the East Coast and even in New Zealand more than once, believe it or not.
When the ionosphere is active, you get "skip" that allows your transmissions to cover extreme distances.
LKG
Larry
Boise, ID
23 JLUR (soon), Gen 2 Cummins, 22 Sport Alt. R.I.P
Hey guys/gals
Cheers
Have you considered GMRS? I feel like the majority of this community is heading that direction.
AC77
AC77
AC Abegian
Los Angeles
GMRS ? i will look into that , tnx
rivercrossing
Ben
Bronco
In the mountains I would get less then a mile with the last CB radio I had. I did much better with GMRS radios.
You need to get the type of radio your friends have so that makes the choice between radio types not really a choice.
Most of the time our trucks are within sight of each other so range does not matter.
2nd 392
Ca
Yep— get a CB like my galaxy with a built in 40 watt amp (800 channels) to get out more than a few miles over the BS. It pushed either a Falcon 500 upgraded to 750 watts with 3 - 250 watt tubes and power supply or a 1 KW Messenger . Heard from the grapevine to Roseville (~400 mi) Australia etc, conditions permitting …..“Your Mobile !!!”….. ? The old tube type well out modulated the “more powerful” transistor, but sucked all 4 batteries and dimmed the lights. ?
LKG
Larry
Boise, ID
Notarubicon YouTube channel will have anything and everything you could ever possibly want to know about comes. The guy is a crack up too.
zouch
Berkeley, CA
XJ, JLUWD
antenna makes a huge difference in range.
question i have is;
where do y’all put the dang transceivers in a JL?!
SparkleTooth
Earth
Stellantis SUCKS
CB - Very limited distance (Very few still use CB although there are some)
GMRS - Can communicate for miles depending on topography, dependable and requires an FCC license although there is no test involved just a fee ($35 if I recall)
HAM - Large distances (nationwide or further) Requires a training, a test, and a fee. The ultimate in communication but not too many folks on the trail will be using it.
Some use all 3 or a combination
AC77
AC77
AC Abegian
Los Angeles
question i have is;
ive seen holders/brackets, that you can mount around the head unit , dash, or install a molle overhead an mount it there
AC77
AC77
AC Abegian
Los Angeles
i've heard ham radios will need a lot of power and they may cause a fire with the automotive 12v system ?
2nd 392
Ca
You need to use the appropriate wire/cable/connectors is all. I used #2 welding cable (fused) and pallet jack connectors on the big amps run direct from the batteries. Like for a winch. Failure to do so Can and Will result in a fire— I have seen the results of 2 fires from not doing so. The company banned further amp installs due to a couple idgets, among other rules caused by a couple idgets . ?
AC77
AC77
AC Abegian
Los Angeles
copy that
