Brown Sludge in coolant system
stevensons00
Jeep
NC
2002 Jeep Wrangler Sport
2002 Jeep Wrangler 110K miles I6 manual, no A/C- I had a leak in the radiator and noticed that the coolant was brown muddy water. I replaced the radiator, thermostat, water-pump, radiator hoses and 1 heater core hose (All original). I back-flushed the heater core and flushed water through the engine block. Refilled with new coolant (orange), ran it for about 30 min, held temperature and no leaks. Went out next day to check coolant level in radiator and the muddy water/sludge is back. There is no white smoke out the back that I can tell. Oil looks normal, no milky appearance. I am at a lost as to what to do next? Any help would be great.
kah.mun.rah
Merenkahre Jr.
Duat
Any drop in your oil level?
TucsonDweller
Braden
AZ
2020 Rubi 2.0 eTorque
Blown head gasket? I’m not sure what your describing fits that problem, but it’s a possibility.
stevensons00
Jeep
NC
Nothing more than normal. I've read where oil can look milky is the coolant and oil are mixing and when I pulled the dipstick it looked normal.
stevensons00
Jeep
NC
What would be the best way to trouble shoot a blown head gasket?
TucsonDweller
Braden
AZ
A compression test, while not 100% accurate, is a good place to start. Google would know more than me.
kah.mun.rah
Merenkahre Jr.
Duat
Coolant + oil looks like chocolate milk. Any oil leaks on the outside of the engine?
stevensons00
Jeep
NC
There is evidence of oil leak on the outside of the engine block in the area of the dipstick, but the dipstick still looks normal
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
It's a 2002? Rust inside the engine block. Who cares. Flush it multiple more times and it will probably come back. Or just leave it.
stevensons00
Jeep
NC
Check at the oil filler cap. Often you will get milky foam around that.
Thanks. I'll check before and after I drive it today and see if I can see that.
stevensons00
Jeep
NC
Hoping it is that simple!
stevensons00
Jeep
NC
UPDATE: I did some recommended trouble shooting last night. I've got bubbles in the coolant in the radiator. So going to do some additional tests for possible head gasket leak.
roaniecowpony
Retired Engineer
IIRC, there's a specific gravity check of the coolant that should reveal a head gasket leak.
