Low coolant
Egralia
Emerson
Palmetto Bay, Florida
2020 Jeep Wrangler Willys
Last week I decided to check the coolant level on my jl willys 2.0 which is less then a year old with 17000 miles. When checked there was nothing on the dipstick for coolant tank. Yes the 2.0 have a dipstick since the tank is black not clear like the 3.6. When I checked inside, the level was well below min mark. I refilled it to the max mark and it took a litre of coolant to reach that level. Couple of days later I checked the level again, it was at the min mark. I decided to take it to the dealer to see if there was a leak anywhere in the system. The vehicle has never overheated and the temp stays around 192-220. When I picked up the jeep they said that they couldn't find any leaks and its holding pressure. So how does a vehicle lose about 1 litre of coolant. Or maybe the factory or the dealer never filled it to the correct level.
Whiskey 13
Northwest Florida
2020 JLUR White Rubicon, Warn 10000 Lb. Winch Syn. Rope, 35X12.5 KO2
My 2.0 has to be topped off every few thousand miles, I have no leaks but is just something I check on a regular basis. My engine has never gotten hot but don't want to have it overheat because I did not check it. Just for information, the only time I ever had no fluid on the dip stick it took me 3 or 4 fillings before the fluid level would remain the same for a couple days worth of checks.
