- May 9, 2018
- Multiple places..
- '18 JL Rubi, '22 Prevost M H3-45,'01 Harley FatBoy
@Ribs33I'm having the same issue with a blank tire pressure reading from the LF tire. I rotated tires to see if it might be a TPMS sensor in the tire but the LF is still blank.
Has anyone been able to locate the TPMS receiver on the frame for the LF, and if I replace it would it need to be programmed or is it plug and play?
2018 JL Rubicon
I look forward to the info you ferret out so to speak in regard to the JL, TPMS receiver or receiver's...
As recently as 3 weeks ago, I had a dealership Tech tell me that there 3 receivers on the frame of a JL... that is the way it used to me with the Wranglers, so figured the Tech was just telling me something I thought was still correct/current.
Anyway, if indeed things have moved to a single TPMS monitor, mounted in one place versus 3 receivers mounted on 3 different places on the frame, then I sure would like to know more about this.. I'm sure other's here would like to know current info on this also.
...Would like to know how the single monitor worked so to speak. I knew how things worked with 3 frame mounted sensors... but with one monitor, not sure how it would work.... Hmmmmm...
Hopefully, you find out lots and then come back and tell us that indeed there is only one TPMS receiver and not 3 and how that set-up comes into play so the JL knows what TPMS is where, etc..
I would like to know and I will surely let that dealership Tech friend of mine know..
