What color? It's difficult to tell from the picture, but it looks dark.Was just under the front of the Jeep, doing some recon for my future flat tow setup, and found oil/lube across the backside of the swaybar disconnect skid plate. For the life of me I have no idea where it's coming from.
Did someone change the oil recently? Looks like a good place to collect oil if the filter was mishandled or dropped.Was just under the front of the Jeep, doing some recon for my future flat tow setup, and found oil/lube across the backside of the swaybar disconnect skid plate. For the life of me I have no idea where it's coming from.
This was my thought in terms of residual oil.Did someone change the oil recently? Looks like a good place to collect oil if the filter was mishandled or dropped.
That’s probably your best bet. Make sure you show them the photo as well so they have an idea if you wiped it clean. New Jeep, let the dealer handle it as it may drive you crazy looking for answers on your own. Good luck and report back! That’s how our knowledge base here grows and it could benefit someone in the future!I've got an appointment to take it to the dealer Wednesday. I'll let them investigate further. If I hadn't been under it for something unrelated I'd never of found it, at least until I started to see spots in the driveway.
There's only 600 miles on the odometer, no oil changes yet.
I already sent them the photo.That’s probably your best bet. Make sure you show them the photo as well so they have an idea if you wiped it clean. New Jeep, let the dealer handle it as it may drive you crazy looking for answers on your own. Good luck and report back! That’s how our knowledge base here grows and it could benefit someone in the future!
Good deal, glad you’re getting taken care of man. Better to be safe than sorry.I already sent them the photo.
While there they'll also be checking torque specs on all steering & suspension components. While not as severe as some have reported, it does wander.
As an immediate measure..make sure the oil filter and oil fill caps are tightened securely.Was just under the front of the Jeep, doing some recon for my future flat tow setup, and found oil/lube across the backside of the swaybar disconnect skid plate. For the life of me I have no idea where it's coming from.
