spurly
First, I want to be clear and say that I did NOT break the body mount bolt. All bolts are still intact.
I also posted in the broken body bolt thread but I didn't want this to get lost.
In an attempt to get ahead of the war on body bolts I was trying to be proactive as soon as I picked up my JLUR. I know at some point I'll be installing sliders and I wanted to lower my chances of a broken bolt in the future by removing as much loctite as possible now, since the Jeep only has 40 miles.
Having read most of the broken body bolt thread before, I was aware of the possibilities. I rounded up my tools, laid on the creeper and started with the driver rear body bolt. Didn't even make it half a turn and I heard and felt something snap. I thought, shit I broke a bolt. But for some reason I couldn't get the bolt out. Everytime I turned the wrench, I would feel a bit of resistance and then it would spin freely for half a rotation then encounter resistance again. It would repeat this with each turn slowly backing out. I was confused. At the same time, the bolt could freely move up, down, and all around, but just wouldn't come out. Once I got the bolt out, I realized i didn't break a bolt........ I broke the damn nut inside the mount. SHIT
I'm not entirely sure of the construction on the body mounts, but the nut inside is either molded in, welded in or it's a flag nut of some kind. But rest assured, it was now free of the body mount. I spent 30 minutes with a dental pick trying to realign the nut (or threaded portion, whatever it is) inside so I could try to reinstall the bolt. Somehow, I was able to catch a thread, and by holding on to the washer and applying downward pressure while screwing it back in with an impact (very slowly) I was able to get it tight and torqued properly.
So my question, has anyone else experienced this? Is it possibly to just replace the molded rubber body mount to fix my issue? Does anyone have any pictures of the body mounts? At this point I don't want to take it apart again, without knowing for certain I can replace the mount or I'm installing sliders.
The rest of the bolts came out with zero issues. I took a wire wheel to each bolt to remove the loctite, reinstalled, torqued, and called it good.
