Best way to modify tpm warning?
drdriller
Houston
2019 jl
i want to disable my tpm sensor warning on my jl. What’s the best way to do that? I’m not interested in any of the other features that the tazer offers.
OversandJL
Massachusetts
2018 JLUR, 2017 JKU Sahara, 2014 JKU Sport S, 2007 JKU Sport, 1997 TJ,
Tazer
drdriller
Houston
2019 jl
How about tazer lite? What is the light show
HoosierJL
Fletch
Lafayette, IN
2019 JL Rubicon
I already owned the Superchips Flashcal F5, so I purchased a 3rd party bypass for the security module, updated the firmware on the Flashcal to the latest version and adjusted my tire pressure to have 31PSI as "normal." With the factory default 37PSI, the low pressure warning was coming on at 29psi, which I hit one cold day when parked outside at 10 below zero.
I have been running 33psi in my factory Rubicon tires, but just today lowered to 31 to try out.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
I used my Tazer JL Lite to lower the threshhold from 36 to 30. Tire pressure has dropped to 28 and no warning light. I'm guessing it has to drop to around 24 to trigger a warning. So far so good.
xeon
JLU Rubicon
I think I am going to get that Tazer. This TPS setting is utterly useless to me. I try to run my tires at 33/34 by a decent pressure gauge but when you see the warning that looks like this, I am baffled at the logic it uses. Whats more strange was after the next stop in my drive that day... the only remaining error was the tire in the upper right at 33 while the others were 32 and 31. Oh please..Tazer, make it stop.
Jeep Wrangler JL Best way to modify tpm warning? IMG_4826
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
If you set it at 30 will get an alarm at 25, I don’t think you can go lower than 25 as it has something to do with what logic is hardwired innto the JL
JIMBOX
JAMES
FERNLEY NV
RETIRED
I got rid of mine !
W.E.
JIMBO
