BATTERY KEEPS DISCHARGING AFTER TRANSFER CASE REPLACEMENT
RDoverland
Tom
New York
2020 Jeep Wrangler
Hey everyone,
I recently replaced the transfer case on my 2020 Jeep Wrangler JL Sport S with the exact same model as the original. Everything went in smoothly, but since the install, my battery keeps discharging overnight.
There were zero issues before the swap, so I’m trying to trace what could’ve gone wrong during the process.
To remove the transfer case, I had to lower the transmission. Could that have affected any electrical wiring or ground connections? I’m wondering if maybe something got pinched or stretched, during the reassembly. Where would the wires be located?? Has anyone experienced a parasitic drain after doing drivetrain work like this?
Here’s where it gets even weirder…
After unplugging the battery for about 30 minutes to reset everything, I started the Jeep the next morning and my Sport S flashed the Rubicon logo on the dash. Uh… what? 😅
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
IIRC, you can pin test for current draw across each fused circuit to identify which one it is.
Park it, pop the hood and pull the fuse box cover, let it go to sleep.
Get pins out for your multimeter, set it in a low amp reading and go to town.
I'd expect you're seeing over an amp of draw if it's killing a brand new battery overnight.
Jeep Wrangler JL BATTERY KEEPS DISCHARGING AFTER TRANSFER CASE REPLACEMENT 1752244023993-
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
Hey everyone,
It was a lot of years ago and cars have changed a lot, but I had the same issue after replacing the clutch on a VW Rabbit. It turned out to be a loose ground wire on the transmission. Make sure to check all the ground wire and make ensure they are tight...
RDoverland
RDoverland
Tom
New York
2020 Jeep Wrangler
So I checked the wires and didn’t see anything loose or disconnected. It all seems ok. I also checked for a parasitic drain and didn’t find anything. Maybe it’s just a bad battery…??? Maybe it is just a coincident and it just gave up after the new transfer case installation. Idk.
azjl#3
North AZ
how old is the battery?? What is it's engine off voltage
RDoverland
RDoverland
Tom
New York
2020 Jeep Wrangler
It’s my first battery. I had it since I bought the jeep in 2020. I just disconnected the battery and will let it sit unplugged overnight to see if it drains on its own.
azjl#3
North AZ
Get thee to a battery store post haste my friend. You have dead batteries, not discharging batteries...
GATORB8
CLT NC
Shit, can’t believe I missed it was an OG battery and made you do that. My OEM gave up in 24 months.
azjl#3
North AZ
do you have a second battery i take it you do, replace it as well.
Terrymo
Terry
2023 JLURXR 3.6 ET
Mine lasted about 2 years as well before I lost confidence it. I preemptively change all our automotive batteries rather than trying to squeeze every last day out of them.
RDoverland
RDoverland
Tom
New York
2020 Jeep Wrangler
It’s just so weird that it happened right after I replaced my transfer case. No warning signs at all.
