Battery replacement
REW48
Ronnie
Parsons, KS 67357, USA
2018 Jeep Wrangler Rubicon JL
Went to replace the batteries in 2018 Jeep Wrangler Rubicon JL with the 2.0 liter engine and auto trans. and found out mine didn't have the second battery in it. It has the box it sets in but no battery or leads. Replaced the main battery and now my power steps won't retract. They start to then just stop. Am I overlooking something?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Went to replace the batteries in 2018 Jeep Wrangler Rubicon JL with the 4.0 liter engine and auto trans. and found out mine didn't have the second battery in it. It has the box it sets in but no battery or leads. Replaced the main battery and now my power steps won't retract. They start to then just stop. Am I overlooking something?
yes. For one, that engine doesn’t exist.
do you mean the 4 cylinder, the 2.0 turbo? The secondary battery there is the 48V etorque battery.
REW48
REW48
Ronnie
Yes 2.0 turbo and it doesn't have the second battery in it.
mwilk012
Oklahoma
Service
It does. You just don't know where it is and have no business changing it yourself. Your problem with your power steps needs to be looked at on its own, what brand are they?
carlhenry
carl
couch
1999 wrangler jl 2.0
the second battery is under the left rear seat under the jeep
REW48
REW48
Ronnie
AMP Research on the power steps. Why is the reason I have no business changing the 2nd battery myself. You Tube videos show it to be under the hood under fuse and relay box.
carlhenry
carl
couch
domt know it has water and air cooling lines going to it
TheNewGuy
Wes
NH
2021 Jeep Wrangler Sport S 2 door
Enigineers :(
Your talking about 2 very different batteries. The one under the hood is for the start/stop function non-eTorque systems. Easily replaceable and available at auto parts stores.
The battery under the back seat is a lithium-ion Nickel Manganese Cobalt (NMC)-Graphite battery and is part of the e-Torque mild hybrid system. It's actually not inside right under the seat cushion, it's on the undercarriage below the rear seat area. Replacing it is a lot more involved than replacing the battery under the hood and you're not gonna walk into a parts store and buy one. It's also covered by an 8 year warranty and very expensive so if there is a problem with it, have it replaced under warranty.
mwilk012
Oklahoma
Service
That is only for the 3.6 with ESS. If you could even get your hands on a 48V replacement battery, you absolutely do not have the means to replace it at home.
mwilk012
Oklahoma
Service
Go to whoever installed the steps and have them take a look.
carlhenry
carl
couch
i have that battery in my 2.0 so its not only 4 the 3.6
Down South
Sam
Louisiana
2020 JLUR
D
Did you purchase your Wrangler used? If so maybe the previous owner modified it to use only one battery?
If not, your start/stop battery will be under the first battery.
This is a YouTube link showing how to get to it.
YouTube Vid replace Start/Stop battery
I have no idea why your steps are not working correctly. You say they start to retract then quit. I was wondering if they were powered directly from the battery you replaced. I was thinking bad connection but if they are trying to work, it doesn't sound like a connection problem.
