rirealtor
- Dean
- Jan 21, 2024
- Rhode Island
- 2018 JL Sahara Unl, 2022 GC, 1975 Wagoneer
Replacing the main battery in my 18 and even after doing the fuse/ground cable bypass still have the stop start unavailable; service system message at start up.
Unfortunately when re installing the battery hold down the bolt snapped in the cold temps as it was being torqued in. It was bent at factory( also found a rusty torq bit in the battery tray!)
So- question- what can be done to secure the battery without the side bolt access?
Drill it out? Maybe a strap down system across middle? With the H7 size, not much room on the ends for the universal hook trays- but I’m not sure how that would even work..
Thanks for your advice
