That's what I am hoping but my last Jeep was never that bad.The MPG should improve some with engine break in and computer learning your driving habits.
Yeah 3.6 in bothSame engine?
Both have the same gears (4.10) and same rear axles.Your rubicon had different gears. You probably had 4.10 gears and the Willy’s without recon package is 3.45.. however I do have a 2021 Willy’s with 2in lift and 35’s and get between 18-20 with my stock gears 3.45.. I also have the 2.0T
Yeah 3.6 in both
same here, maybe even a bit more of an MPG loss. my Sahara on Rubi-sized wheels and a ~2.5” lift went from ~18mpg to ~13MPG in my same usual and unfortunate suburban driving pattern.Given you went from one Jeep to the other, time of year wouldn't be a factor here, but this is the time of year (winter / ethanol) where my mileage goes down 2-3mpg.
I've recurringly calculated the effect of winter-blend gasoline on my average fuel efficiency, and have landed at a reasonably fixed -2.5 MPG. This is with no other changes on the vehicle or with my driving habits.my Sahara on Rubi-sized wheels and a ~2.5” lift went from ~18mpg to ~13MPG in my same usual and unfortunate suburban driving pattern.
SHOULDA BOUGHT AN ECODIESELI traded my 2018 JL Rubicon for a 2024 JL Willys. My Rubicon that had a 3 inch lift and 35s averaged 19 MPG. My stock Willys is only getting 14 MPG. Driving pattern is the exact same. Has anyone else noticed this?
Denser air negatively impacts aerodynamics, but don't forget that it also contains more oxygen so it burns more efficiently.I do sometimes wonder if the denser winter air has any effect on the aforementioned calculation, but that's not a rabbit hole I'm interested in descending at this time.
