AUX battery not available
sweet88gt
FL
20 JLUR 24 VW Tiguan Rline 20+21 Tacoma TRD
Just went through Hurricane Ian and I have limited access to internet or cell service.
Jeep said Aux switches not available. Im guessing my batteries are going bad. Just didn't have time to scroll through the search function. Thanks
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Battery voltage is low. Run engine to charge them or connect to a battery charger. Hopefully they aren't dying right now.
Be safe.
sweet88gt
sweet88gt
FL
Be safe.
Probably because I was using the jeep to listen to the radio during the storm. I had not started it in a couple of days. Lets hope thats all it was.
  • Like
Reactions: GtX
sweet88gt
sweet88gt
FL
So far the light hasn't come back on. Service still hard to get. Can anyone recommend the size for the 3.6 ? Its hard to search at times.
sweet88gt
sweet88gt
FL
Thanks Ill look into the battery. Nothing is open like that to get one so fingers crossed
txj2go
DFW
The small battery is not essential. With most JL you can just disconnect the cable and go on with your business.
sweet88gt
sweet88gt
FL
So Im going to bring this thread back just for a quick question. So I have been busy with post hurricane work and fixing of the house.
Aux not available came back on Sunday when I washed the Jeep. Today came back on first start up when heading out to work. I forgot this Jeep is still under warranty at 19,000 miles and till May of 2023. I call the dealership to set up an appointment and they are telling the the battery test can take 5-6 hours to perform to see if the battery (or batteries) are in normal range.
Is that a normal procedure due to warranty ?
I have a load tester I can use at work but is their test some kind of special test because of dual batteries ?
Vanburi
North Texas
2019 'Mojito' JLR
It can take a couple of hours just for the test. 5 to 6hrs would be the total time I would imagine.
Whiskeybiskit
Donny
Las Vegas
2019 JL wrangler sport s
Dealership told me the same thing when I got new batteries. Something about Chrysler/fiat/Stellantis wanting the tests done for warranty work. I was past warranty and paying out of pocket so I didn't need the test.
sweet88gt
sweet88gt
FL
Ok it just seemed odd that I have to leave it for the test to be ran. I asked how long and the response was 5-6 hours.
Thanks
Beachcomber72
2022 JLU High Tide
Advance Auto Parts has both batteries you’d need in stock. Grab both in the Diehard AGM versions.
bigfoot21075
Robert
Maryland
2021 JLUR, 2012 Ford F350
No you can't. You must first pull a fuse (42 I think) BEFORE you disconnect the motorcycle battery. See the GREAT thread Rhinebeck01 posted above
bigfoot21075
Robert
Maryland
Mine has been disconnected for 2 years with no problems.
And you still have the fuse 42 in place? Is your a very early 2018? I know the early ones had different software...
