AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
I think we actually agree in a different way. You see I'm for keeping the ESS/Aux battery in place, just taken out of the electrical schematic of the vehicle...for those that is wishing to abandon ESS. So my positive cable never gets touched, just the negative between both batteries negative posts get disconnected at the main battery, and that end insulated.I'm not sure I agree. To me KISS would indicate keeping as much of the factory wiring intact (as in not destroyed) as is readily possible and keeping positive terminal connectors as robustly protected as possible.
Ok, here's the fly in that ointment for me. I don't disagree with your wiring observation, I just wonder if its moot. You see anyone taking the ESS battery out of the schematic should either be pulling Fuse 42, so the PCR never can engage, and N1/N2 can never separate anyway, or they're going with the original fused jumper approach between N1 and N2 (or both methods if their redundant) and in either case, N1 and N2 are to never be separated again anyway. Maybe I am mistaken and/or miss your point Foster. If so, my bad.The aux positive wire terminal connector crimps around 2 wires, one to N3/PCR and the other to N1. Attaching the aux battery cable terminal connector to the main battery terminal effectively jumpers N1/N2 and bypasses the PCR.
Here again I take no issue with this except to say I never concerned myself with an insulated but dangling cable connected at one end originally to the positive of the ESS battery because unlike you (which is fine, different strokes different folks) never considered it worth it to remove the ESS battery or this cable's connection to its positive terminal.Doing so also helps prevent the stock terminal connector between N3 and N1 which is exposed when the aux battery is removed from shorting (better than wrapping it in electrical tape and leaving it floating around the battery tray, anyway).
As a sealed AGM battery I'm not too worried about it staying in place neither tapped nor charged. But you would certainly have a fair point in saying that the battery which is removed is certainly the battery, if it is compromised, that never causes issue in the vehcile.
For those removing the ESS battery like you, I have no issue with your logic.Granted, this arrangement creates an extraneous connection between the main battery positive terminal and N3 (through the PCR), but that seems worth the tradeoff of avoiding permanently altering the factory wires/connectors.
To which I'd like to talk about why. Shane runs ESS and regular stuff off of one battery, saving the other for managing overland appliances particular with the engine off, right?The Genesis dual battery system installation recommendation jumpers N1/N2 by attaching the aux battery cable terminal connector to the main battery positive terminal (as I described above). There's no mention of fuse F42 because the PCR is bypassed so the relay closed/open state is irrelevant. The recommendation isn't related to anything specific about the functionality of the Genesis system, it's because the system deletes the original aux battery and it's a clean way to manage (or "groom" as Shane would say) the stock battery cables.
With one battery doing regular and ESS work, separating N1 from N2, i.e. taking the two factory batteries out of parallel no longer becomes required.
