Automatic transmission maintenance
KELove
Kent
Matthews, NC
2018 Wrangler Unlimited JL Sahara
How often are you changing your auto trans fluid? Wrangler JL
Heimkehr
Pennsylvania
2021 JLU 2.0T
The 850RE in my JLU gets new transmission fluid and a filter every 60K miles, per the guidance from ZF themselves.
I drain and refill the fluid at least twice, with 1K miles in between each service. The system capacity is ~9 quarts, but from experience only 5.5 quarts will drain out each time. My selling dealer refused to perform this service, leaning heavily on the misleading "Lifetime Fill" language evident in the Owner's Manual.
I keep a spare OEM pan gasket on hand, which of course guarantees that I won't need it.
This thread will assist the owner who performs the work himself.
https://www.jlwranglerforums.com/fo...ission-service-diy-how-to-instructions.94302/
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Same here. 60k miles fluid and filter. I do one drain and fill though.
nositting
PA
19 JLUS
i did one drain and filter at 45,000 and one at 90,000 (miles). pretty straightforward but can be a little time consuming for newbies like me.
azjl#3
North AZ
Thank you, will do same
Old Dogger
Bill
Cave Creek Arizona
50K miles.
PropDr
Arno
Eugene, Oregon
JL Rubicon 2D. Raptor, Fat Bob, El Diablo, SLK 55 AMG 030 Compressor
Over a week ago changed the transmission fluid on a 2020 JL two door; got it used a couple of months ago with 76K miles on it.
The fluid was near black, no abnormal smell, magnets covered with super fine wear material.
Drained about 5 quarts (needed refill was over 6 quarts)
Changing the fluid to AMSOIL.
Cleaned the pan, reinstalled with old filter, filled with AMSOIL.
Note: with the JL level, I could only get less than 3 quarts in (in the two door, the transmission sits at a pronounced tilt to aft) jacked up the rear and got another quart in.
After going through the oil level check procedure, I had to add over two quarts.
Ordered a PPE aluminum pan (better cooling and will take more fluid)
Installed it today.
Note: AMSOIL is red, the oil I removed was a dirty dark red.
I will be doing one more fluid change (good thing the PPE pan has a drain plug, no need to remove the exhaust crossover pipe to remove the pan)
All this just to say: Change the fluid at 50K or less, that lifetime fluid claim by Jeep is BS!
Oh, and the fill plug on the two door is a mother effer to get to, you got about an inch clearance between the tranny and the fuel tank to get to it...
ShellNate7974
Nathan
South MS
2025 Wrangler Willys 4dr
Do you have a link for the PPE pan? Having a drain plug would be super helpful before dropping the pan.
Installed it today.
ShellNate7974
Nathan
South MS
