Crowbar
Find another shop. And get Dana Spicer gears.So i got a quote today from a reputable shop.
Parts and labour for a regear with Yukon gears, $3,650 CAD …. Oooooooouch
^^^^^Find another shop. And get Dana Spicer gears.
That's expensive AF, shop around for sure. I got a deal from a shop I ran into at an off road expo, I paid $1500 total and that was with the REM polished upgrade.So i got a quote today from a reputable shop.
I did reprogram , it helped with shift points around the city. But still trashDid you reprogram for the larger tize size? If not, that is a major part of the issue.
Wow that sounds greatThat's expensive AF, shop around for sure. I got a deal from a shop I ran into at an off road expo, I paid $1500 total and that was with the REM polished upgrade.
You do need it. It is the bearings, bolts, shims, etc. required to install the gears. You will need one for each axle (they are different though).Hey guys, thanks for all the replies this thread has been super helpful
While i’m still pricing out i had a shop ask me if I need a master install? What is this and do i need it?
FYI 3 shops now seem to be on the side of 4.88s for my needs and my area.
thanks
Thank you sirYou do need it. It is the bearings, bolts, shims, etc. required to install the gears. You will need one for each axle (they are different though).
If you install gears you need to use a master install kit.Hey guys, thanks for all the replies this thread has been super helpful
thanks
For an auto 4:88 is fine , go Dana /Spicer . if you want to go for a drive ," Enrico"s differential solutions" in mission BC is good . lots of experience with JL 'sHey guys, thanks for all the replies this thread has been super helpful
thanks
Thanks man, btw the red two door with colour match—- good choice !For an auto 4:88 is fine , go Dana /Spicer . if you want to go for a drive ," Enrico"s differential solutions" in mission BC is good . lots of experience with JL 's
