Caymanedge
- Jul 8, 2020
- North Coast
- 2020 JLUR
Looking for someone who has installed the Redneck Ram hydro assist steering?
Have you looked at West Texas Offroad's website? It has pricing right on there.What is the price for the redneck ram with and without sending in a core?
Ya it just says starting at 799.00Have you looked at West Texas Offroad's website? It has pricing right on there.
Being able to turn the steering wheel while a tire is aired down and under the extra load of climbing.I gots to ask the question: What is the Objective and what will you accomplish? Is the steering on your JLUR failing or???
KEEP in mind its YOUR JEEP, your wallet and I don't a dog in the hunt...
@Headbarcode has a great answerI gots to ask the question: What is the Objective and what will you accomplish? Is the steering on your JLUR failing or???
Crawling in the rocks with my 37" KM3's aired down to 13 PSI, I frequently can't turn. I can live with that as I'm building the most capable budget JLR now that I will sell next year after MOAB to start an extreme build. So I'm not putting any money into unless it's urgently needed.Being able to turn the steering wheel while a tire is aired down and under the extra load of climbing.
Some members have even reported of not being able to turn the wheel while aired down and simply sitting still on a dirt and gravel path.
I didn't have any noticeable increase in resistance when turning my 40x13.5's at 14psi, until trying to climb an obstacle. I don't have any hydraulic assist on my JLUR.
Interesting…I ran 37s (GY/BFG KM2s) at 3-5 psi on my Rubicon Tj OEM steering box* 12 + trips to Moab, Rubicon and trails from Tex - Cali, putting almost 100k mi over nearly 10 yrs wheeling full time@Headbarcode has a great answer
I've also blown a front bead several times (on stock 7.5 narrow rims, poor mans beadlock LOL) - so on BF I ordered beadlocks and NITTO TRAIL GRAPPLER M/T 38X13.50R17LT
I plan to air down to about 9 PSI. Nitto's are 2" taller than my KM3's which are really nominal 36's - actual 35 13/16" & nitto's 2" wider - so the problem is about to get much worse.
I can live with not turning while applying I'd guess 40 lbs force on the steering wheel. What I can't live with is a broken sector shaft or some other component that prevents me from being pulled by another jeep to the road. I'm careful not to apply too much force because I'm afraid of breaking my steering.
Currently I can easily turn on pavement, not moving, aired down.
Did your 03 TJ have a conventional belt-driven power steering pump or the modern electohydraulic type?Interesting…I ran 37s (GY/BFG KM2s) at 3-5 psi on my Rubicon Tj OEM steering box* 12 + trips to Moab, Rubicon and trails from Tex - Cali, putting almost 100k mi over nearly 10 yrs wheeling full time
* OEM steering box on 03 Rubicon was a MB truck unit IIRC…
Maybe this: FIRST time I drove a tractor, ranch truck, hay truck or anything else with power Mac steering was in 1975…been driving for 15 years by then…also first AC
Cannot recall, however it was it was Rubicon 1 and being the first one my guess is it was belt driver…Did your 03 TJ have a conventional belt-driven power steering pump or the modern electohydraulic type?
Belt-driven power steering pumps are stronger, which is why your 03 TJ didn't flinch at larger tires with low air pressures. The downside to that type of power steering delivery is the parasitic loss to engine power.Cannot recall, however it was it was Rubicon 1 and being the first one my guess is it was belt driver…
