Any engine with ESS
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
The turbo doesn't spin when the engine is off. It runs off exhaust gases, so if there's no engine running, the turbo isn't spinning. There's enough oil in the system to lubricate the bearing in the meantime. And it's not off long enough to worry about coking the oil - same with the top end
In the Jeep manual it is noted that depending on the use of the vehicle (roads, highways or trailer use) the engine should be allowed to idle for one minute or more.
If I drive long and fast on a "high way", then I come to a red light, I stop, the ESS starts, the engine stops.
How can the oil still flow to the turbine shaft of the turbocharger (via the oil pump), which is still running, when the turbocharger has just been activated a short time before.
It's in this logic that I wonder how the mechanics can withstand these constraints.
emptyminded42
Cleveland, OH
Hellayella JLU Sport S 6MT, Forester XT
Engineer
Probably there's enough head pressure to keep oil flowing for a brief while. And during ESS, it's not going to be shut off for long periods of time - maybe a minute or two while you're waiting at a light. Then your engine will restart and oil will start flowing and cooling again. Coking of the oil likely doesn't occur during such short timescales.
The recommendation to continue idling for at least a minute or more after heavy loads is to help cool down the system before shutting down the engine for a long period of time. During these longer periods where the engine is off, you will have no oil flow but could have high temperatures in the turbocharger for hours instead of the minutes during ESS. These longer period of time with hot, stagnant oil could contribute to the oil coking and damaging the turbo.
Trailnut
Mitchell
North Texas
'15 Chevy Colorado, '20 Jeep Willys
Fire Marshal (Retired)
Yes almost anyone that lives in a place with summers similar to HELL will complain when you stop at a red light and the engine and A/C shut down!
RSK
SC
2016 Wrangler 2015 Renegade 2020 Gladiator Rubicon
Senior Director of Engineering & Facilities
No side effects whatsoever and compatible with Superchips devices: https://www.smartstopstart.com/jeep-dodge-chrysler-products.html
(and a forum sponsor).
Been using the Smartstopstart for over a year with zero issues. It paid for itself in the first 125 button pushes that I didn’t have to press. Great investment IMO and one of my favorite easy to do mods. Life is better with no ESS and wear/tear on my engine.
I have a Hyundai Ioniq hybrid that gets 55 MPG as my daily driver. It’s designed with the ESS to run off the hybrid battery. As for my Jeep, how ‘bout NO!
Jeep Wrangler JL Any engine with ESS 552CE1D1-7F22-4D01-B1C7-C9964836F31B
RoadiJeff
St. Louis
2020 2.0T Recon, 2018 3.6L GC High Altitude
The ESS will not shut down the engine if the cabin temp has not reached the setpoint.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
The folks that keep their Jeeps long term, it will be interesting in 15-20 years to see the engine life comparison of the pro ESS people as opposed to the people that never use it.
I’ve gotten so in the habit of hitting that button immediately after starting that I rarely ever forget anymore. As a matter of fact I sometimes start my keyed work truck and by habit move my finger over 5” looking to hit the button.
Jitzy
Orlando, Florida
2020 JLU Willys
Retired Police, Now Certified Custom Club Fitter
As soon as the engine shuts down and it starts to blow that not so cool air here on a hot florida summer day you realize you don’t want ESS.
DizzyIzzy
Izzy
NYC
2020 AEV JL370 - Hellayella JLUR
I’ve noticed this with ESS, if your A/C is on and the engine shuts down at a stop, after about 10 seconds later the engine comes back on again without releasing the brake. I think it’s because the A/C is on and it doesn’t want it draining the battery.
Does anyone have a high mileage JL that they use the ESS with? I wonder how it operates after some years and miles of constant use.
I always have a fear that when I’m at an intersection waiting to make my turn, the ESS will kill the engine and I’ll get T-boned by the oncoming traffic. Or one day the AUX battery will start acting up and will shut my car down while I’m in busy traffic and will cause an accident. I can’t get over it and I always turn the bloody thing off. I do this with all my cars.
RoadiJeff
St. Louis
Once again, the engine will NOT shut down if the cabin has not reached the temp setpoint. That's one of the dozen or so items listed in your owner's manual that say they will keep the ESS from working.
Jitzy
Orlando, Florida
2020 JLU Willys
Once again, as soon as you stop at a light here and yes it’s gotten to the appropriate temperature it shuts down. I’ve lived with this in 3 cars now. It blows less than cold air and completely changes your comfort level. IT BLOWS, pun intended
