Anti Spin Rear Diff
landon
Landon
Mississippi
2020 JLU Sport S
Respiratory Therapist
New jeep owner here so possibly a dumb question. If I have the upgraded dana 44 rear due to the anti slip rear diff do I have 4.10 gears? Or just a beefier rear axle with 3.45s?
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
You have the D44 in the rear with the same 3.45 gear ratio as on the front.
landon
landon
Landon
Mississippi
2020 JLU Sport S
Okay that’s what I wanted to know thank you! I couldn’t seem to find anything other than what gear ratios came on the sports and Sahara’s vs the rubicons.
blnewt
New Mexico
Just ask @cosine he knows!
You might be able to find a Gladiator take-off front D44 that has the same 3:45 ratio to upgrade that too!
blnewt
New Mexico
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
You have a non Rubicon which rules out Dana 44 Rear/Dana 44 front. You have two choices from the factory, a Dana 35 Rear/Dana 30 front or a Dana 44 Rear/Dana 30 Front. You can check your build sheet online with your VIN and verify. My bet you have the later of Dana 44 Rear/ Dana 30 front.
Tmarshallg78
Na
I have a non-Rubicon and my build sheet states "m210 front axle" along with my anti slip rear.
blnewt
New Mexico
Maybe the diesels get that gladiator front D44, do you have a pic of that front end by chance? Is there a gear ratio listed on the build sheet? I don't remember if they list them there.
Gunfighter
P.J.
West Michigan
2021 Jeep Wrangler High Altitude
Trying not to get warning points
I thought the Gladiator had 3.73s?
Yup, and the 3.6L /2.0L High Altitude Wrangler also has the 3:73's. Basically the same Dana 44's / standard gear ratio as the Gladiator.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
All diesels get the M210 front/M220 rear with 3.73 gears. The Rubicons get wider axles than non-Rubicons.
REDSEAL199
Beau
MO
2021 Wrangler Unlimited Highaltitude 4xe
Pretty sure the 4xe non rubicon still has D44 front and rear with 3:73's.
Gunfighter
P.J.
West Michigan
Correct (4XE also has the 2.0L as part of its hybrid feature) and so do the 3.0L diesel versions along with the non XR Rubicon 392.
