Antenna Hook
MajorDave
Bluffton, IN
2021 Wrangler Unlimited Willys Sport
Brand new first time Jeep owner. Excited for all the customization options. First 24 hours had me add a gas cap cover, a spare tire cover, and running boards. I remember in the Army that antennas were always bent back (or forward, depending on the application) and hooked to the vehicle. I like the reception of the OEM antenna, but would like to bend it back and attach it to the upper A-Pillar with some sort of hook device. I have searched for hours on multiple Jeep and 4X4 sites, as well as the internet at large. I can't even find a reference describing doing anything of the sort. I find it really surprising that no one has thought of this and developed something. Has anyone here ever heard of such a device? If not, there may be some fabrication in my near future :rock:
rk911
Rich
DuPage County IL
'23 Wrangler Sport 2D, '10 Liberty, '46 Willys
Retired and loving it!
Why do you want to do that??.
MajorDave
MajorDave
Bluffton, IN
So it doesn't whip around all over the place while driving, so I can drive though the car wash without worry, and so it doesn't smack the top of my garage door every time I come and go.
rk911
Rich
DuPage County IL
MajorDave
MajorDave
Bluffton, IN
Not that I haven't thought of that - but I read a LOT of complaints about stubbies getting really bad reception. So, in answering the OP question, no one has ever seen this, it seems....
rk911
Rich
DuPage County IL
I haven't had my JL thru a car wash yet but my old TJ had 20+ years of car washes with zero damage to the radio antenna. And the antenna on my TJ or JL does not whip around at highway speeds. Keep in mind that if you bend the antenna you may affect reception on AM and/or FM.
MajorDave
MajorDave
Bluffton, IN
Hadn't thought about the effect of an arc instead of a linear pole. Perhaps some middle ground could be with a 16 or 18 inch replacement. And since I can get one in black, I can rid myself of the only silver on the vehicle, which is Sarge Green with everything else 100% black.
rohdawg
Long Island, New York
Merchant Marine
Jeep Wrangler JL Antenna Hook IMG_8435
The antenna on our Jeeps in the Army were for the comms and three times as long as the OEM antenna on the JL. They were mounted in the back, on a base with a spring and bent forward.
The only reason we tied them down was to keep them from getting torn up in the woods or snapping them off going under the bridges in Germany.
pic of my stuck Jeep on the East/Wes German border circa 1988 for amusement. You can see the antenna bent over the roof.
MajorDave
MajorDave
Bluffton, IN
Nice pic! I am retired Army myself, and absolutely remember those. Seems we had some trucks (maybe the 5-ton, not sure) that had a front antenna pulled back near the cab. Either way - looks like my best bet is a replacement that is several inches shorter without going full-on stubby.
rk911
Rich
DuPage County IL
Is your garage door/entry that close that it will bend the antenna on your Jeep?
MajorDave
MajorDave
Bluffton, IN
It doesn't bend it, but it just smacks the door frame. I'm not worried about damage, it's just annoying.
rk911
Rich
DuPage County IL
Good luck with whatever solution you come up with.
MajorDave
MajorDave
Bluffton, IN
Thanks!
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
Why not just cut an inch off your original antenna and spray paint it flat black rubberized paint. I sprayed mine black two years ago and it's still holding up.
