Alignment is it worth it?
Willywhitie24
NOVA
2024 4door Willys
i just put a new set of tires, is it even worth getting an alignment since only toe can be adjusted? I can do DIY toe adjustment myself.
jadmt
jeff
montana
I Kind of like to know what my caster and camber are. More for my own curiosity than anything
X35
PA
2025 Wrangler Willys XR
Can’t hurt to have it checked. Tires are expensive, no sense wearing them out. Even though only toe is adjustable, an alignment check of camber/caster could show potential problems such as worn ball joints or bent components if those angles aren’t in spec 👊🏼🍻
Decreasing Dave
Temecula, CA
2023 JLURubicon XR
Retired Federal LEO
After the new lift and tires/wheels, I had my alignment guy also adjust the front trackbar and recenter the axle. Mine is the Synergy one that does not have to be removed to adjust, so easy peasy and he has everything he needs to see on the computer already.
toddinrochester
Todd
Rochester NY
2026 Wrangler Rubicon X JLU
Firestone offers a lifetime alignment for like $200. You can go everything other month if you want and I have been getting them on everything I own since the late 90's. I go every few months or after any suspension changes/tire changes. If I have a rough off-roading adventure, I make an alignment appointment.
Roky
Roky
Not worth it to me unless I want to see a readout chasing an issue….
Eyeball
1997 TJ & 2023 JLUR
Somebody has to do it… if you are the type to put it on the list to get around to later, just have the shop do it.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Easy DIY...set toe -1/8" ... will help reduce "wondering"
Willywhitie24
NOVA
2024 4door Willys
The tires i had were used, it had tire cupping on the outside and vibration on the highway. With the new tires the ride is smooth no vibration. I did adjust the toe for slight toe in about 3-4mm.
