Air down on 392 XR
ReconMZ
Moshe
Chevy Chase, MD
Recon JKU 2018, 2021 Rubicon JLU, 2023 392XR
Photographer
What would be the recommended low PSI on the stock, non-bead-locked 35s for off-roading?
Industrialwrench
San Diego
08 SRT Challenger. 18 4Runner off-road premium.
I was romping around at 15psi without a worry in the world all weekend. I’m on stock 33’s but whatever it’ll be similar. I’ve ran 12 psi without an issue too. At 14.7 psi you’ve got twice the air in the tire than it can hold empty. My friend is running 12 psi on 35x12.5x15 so I don’t think you need to worry at or above that. All depends on what you’re looking for. I get a 1/4” clearance change from 20-18 psi…
ReconMZ
ReconMZ
Moshe
Chevy Chase, MD
Photographer
Thanks! Just wanted to be sure. My previous was simulated methods and they had an extra lip, I was able to air down to 6 PSI.
1996cc
Oregon
22 JLUR 392
Depends on terrain and speed. At least 12, maybe 8, maybe 6. Try it and see, reseating a bead isn’t as hard as most think it is…
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Not enough info to recommend specifically, but from a risk perspective, 15psi is a safe number. Can go lower for more serious rock crawling but gathering from your post... you are just starting out off-roading and you won't be immediately be subjecting your 392 to extreme conditions. If 15psi isn't gripping then try 12 or 10. Go experiment.
Go out and air down and see what you are feeling and learn... air down another 3-5psi and see if you notice the difference. If not serious rock crawling and just running on rough trails, 15psi should be just fine.
1996cc
Oregon
22 JLUR 392
Other non-serious reasons to air down lower, sand and snow…
Jeep Wrangler JL Air down on 392 XR 57906C15-1108-4C2F-A1FC-517B54BE76CB
ReconMZ
ReconMZ
Moshe
Chevy Chase, MD
Photographer
Thanks everyone!
