AEV Borah wheels on JL
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
I hear you, but I’m also pretty sure that the oem bolts from Mopar don’t need to be painted to stay rust free. Maybe I’m incorrect in thinking the oem XR wheels come with black bolts; is that correct? And are those like $2.50 a piece (so close to $300 for a set of them?).
Black oxide will rust overnight if not painted. I’m just wondering what the oem finish is that keeps them from rusting. I’m guessing they’re finished with an oem type paint, which makes sense buying wheels and bolts directly from Mopar.
Last question: are the oem bolts socket cap?
Agreed about the black oxide. Without going too far down the rabbit hole.... The Mopar bolts have some form of "automotive" finish on them that protects from rusting. But they still rust. I think they are zinc coated with a black coating over it. The OEM bolts (I believe) have a black oxide coating on them but the coating particulars mean the coating is super thick. So it holds up better. Most of your aftermarket places like Fastenal or Grainger spec a much thinner coating because it is cheaper so it rusts much faster. I certainly haven't verified any of this. It's just my opinion on what's going on. Years ago I had a set of ARP bolts holding a set of wheels together and their black oxide finish has never rusted.
The cost is what gets me. When you install them with a torx bit the coating is going away. So they'll need to be chased with paint after install to stay away from rust. For $15 bucks in hardware per wheel and some paint time you can really cut your costs and have a better setup over time. I've chased all these stupid options with my Friction Double Beadlocks for years. Why I said earlier... it's a no win situation. ?
I feel like the easiest solution is to get whatever bolt you can the cheapest and paint them before install. Then you know what you start with.
So... I suck at bolt terminology I believe all 3 bolts here are socket cap screws. The left bolt is a cylindrical head socket cap. The middle bolt comes out of a 392 beadlock capable wheel and is a button head socket cap(m10). The right is my M8x1.25 button head socket cap screw.
Jeep Wrangler JL AEV Borah wheels on JL SocketCa
dchant
david
york, pa
jeep grand cherokee
unknownsolo
Washington, USA
22 Wrangler Rubicon 4XE
Not yet! They should be here Tuesday. I will post updates and pics once I have them installed, I can't wait!
It took forever to ship, and then the shipment got stuck with UPS for almost a week with no progress.
dchant
david
york, pa
jeep grand cherokee
Oh damn. Thanks for the update. Looking forward to seeing them! Looks like they’re the best option that I can find. And if they’re the same as the bolts on my steel bumper then they seem to hold up to rusting just fine.
unknownsolo
Washington, USA
Every time I am desperately waiting on a delivery, UPS somehow knows and makes sure I am their last stop.
The Mopar bolts are a little shorter, but they work great! The included washers fit perfectly on the beauty ring as it was made for it. Much better than the AEV bolts.
In my opinion, the Mopar bolts and washers make the overall fitment a lot nicer than AEV's. I like how the wheel bolts match all the other bolts on the Jeep, like on the bumper. They look more "OEM".
Jeep Wrangler JL AEV Borah wheels on JL IMG_1237
Jeep Wrangler JL AEV Borah wheels on JL IMG_1233
Jeep Wrangler JL AEV Borah wheels on JL IMG_1235
Jeep Wrangler JL AEV Borah wheels on JL IMG_1238(1)
Jeep Wrangler JL AEV Borah wheels on JL IMG_1240
unknownsolo
Washington, USA
Thanks! You wouldn't need these bolts if you didn't get the rings. AEV has their own set of black plastic bolts to fill in the holes.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
I know this but might eventually get them and will do this for sure then :like:
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Those look sooo much better. The heads look like they're a little shorter too. That might help them from getting damaged.
unknownsolo
Washington, USA
Thanks. I like them a lot, too! Let's see how well they hold up. I haven't seen anyone complain about the Mopar rings, so I am not concerned.
I should also mention Mopar's is 9.8, while AEV's is 8.8.
