AEV Borah wheels on JL
fastfatdude
Chung Yeh
Singapore
22 JLUR
Hi all,
went thru 22 pages on the Borah wheels Phew…
does anyone have the onyx Borahs with onyx protection rings mounted on a bright white JLUR? Didnt see any.
thanks
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
I no longer run these wheels, because the backspace would not work for my set up...however I might switch back
If you originally got theJL wheels you should get the JK version as has better backspacing (4.52 or something like that)
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Bryce
Bryce
Acworth, GA
2019 JLUR
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
What concern / need / desire are these addressing?
John: I like the look of the cap head screws, and I like the look of stainless steel. I think the protection rings change the look of the Borah’s, and then I think the hex head bolts change it even further. And my thought is that a rounded cap head bolt may slide off rocks more easily than the standard hex head, that appear to stick out pretty far.
Bryce, your point of messing up the allen head opening is a legit one I would think. I’m not near Atlanta, but I’d be happy to pay for shipping if you really aren’t going to use yours anymore. If you weigh then, I can send you a shipping label to print and slap on a box. That’s a generous offer, thank you.
Bryce
Bryce
Acworth, GA
2019 JLUR
I'll get them out an weigh them tomorrow and let you know.
Ratbert
PNW
Software Engineer
Maybe they'll work great with the ring. I was picturing them on the base (sans ring) wheel and they'd be less than ideal there.
unknownsolo
Washington, USA
22 Wrangler Rubicon 4XE
Here's some pics of my JL spec Onyx AEVs with different setups. No rings here:
Vs with satin black painted protection rings and black button head bolts:
I'm having an issue with the new bolts rusting (I've tried painting them already). Not sure what else to do; might have to order the OE ones from AEV instead.
What did you end up doing? The bolts I got from Johnson’s ended up rusting after just one week so I took them out and put the OE ones again!
I like the look with black bolts more.
Jeep Wrangler JL AEV Borah wheels on JL 15443B64-10C9-4EE9-9A65-1B57296F6DDB
Jeep Wrangler JL AEV Borah wheels on JL 2A73A3E7-47A4-4CA4-8A87-8050B8FB4D28
Jeep Wrangler JL AEV Borah wheels on JL 8BF26892-6D74-452C-B34B-2EA79FFD5D37
Jeep Wrangler JL AEV Borah wheels on JL 2CFF6489-443E-42F2-A913-A67B6DA869DA
unknownsolo
Washington, USA
Has anyone tried the mopar beadlock bolts with this? I can’t find their size online, but if they fit, that would be a great alternative!
unknownsolo
Washington, USA
dchant
david
york, pa
jeep grand cherokee
I received my JL borah wheels today. 1 of the 5 has a problem with the center cap. It won’t fully seat. And if I swap center caps around doesn’t change. So definitely a wheel problem. Which they are replacing only once I send the other back. I also received a damaged protection ring that they don’t think is damaged “enough” for a return. Lol. I understand it’s a sacrificial part but I wanted to be the one to scratch them up. And to top it off the bolts are all 8.8 bolts. They claim that’s what they use with protection rings even though package says 10.9. So far hasn’t been a great first impression with aev. Had I known I would have looked elsewhere for wheels.
