AEV 2.0 Spacer for Rubicon
jeepnewbie
Raleigh, NC
18' JLU Wrangler Sport S, 08' Toyota Tacoma
GE Aviation
Did you ever install those Rubi shocks and springs?
Nope still running original sport stuff. Lazy. I’ve been debating getting some fox 2.0 shocks. I feel like it needs to stiffen up a bit. I did install some AEV Borah wheels though.
Jeep Wrangler JL AEV 2.0 Spacer for Rubicon 6BC03738-5D7F-4D4B-8F33-BDC596FBE0AF
CaddyshackGopher
North Dakota
2019 Sting Gray JLUR
Installed together with teraflex sport lower control arms. Drives like it did stock maybe a little better. Probably due to greater caster by the control arms.
After I installed the same fixed LCA's w/ the AEV 2" Spacer lift, my caster was +8.5 and it drove great. Based on everything I've read I was a little nervous w/ that high of castor for 4H. I added adjustable front UCAs (I went w/ Clayton) to dial it back into the 6 degree range. Now I truly have a franken-lift. AEV, Teraflex LCA, Clayton UCAs and Synergy front track bar. Handles and rides better than it did at delivery. PS - JLUR
JlRubicon13
Davi
2 door wrangler rubicon
Thanks for letting me know. Did you get any damage from it?
CaddyshackGopher
North Dakota
No damage. I ran it at 8.5 castor (before I added the adjustable front UCA's) for an entire North Dakota/Minnesota winter and zero issues running in 4H. I just feel safer in the 6 degree range based on what I've read.
JlRubicon13
Davi
Makes sense, I’ll take a look at the mopar lca’s. Did you end up flexing it while with the 8.5 caster?
Razvan_JLU
Razvan
Romania
4XE JLUR
Hi guys, is there anyone who installed the AEV 2" spacer kit without the shock extension brackets? I did it because I got an incomplete kit from a friend and need to say I don't like the ride compared to stock.
Thinking if getting the shock extension brackets will improve anything. PS - I also installed the Mopar longer LCAs.
CaddyshackGopher
North Dakota
I'd go w/ shocks designed for a 2'' lift if you don't like the design of the extensions. I installed the extensions and have zero issues but I don't take it rock crawling.........
Razvan_JLU
Razvan
Romania
4XE JLUR
That's what I wanted to hear :) That the extension brackets are fixing the "no extensions" feeling. I also use my rig for 95% on-road.
jamiedtolbert
Jamie
maryland
2021 wrangler jl rubi
They were substantially cheaper than the brackets, are factory parts, and don’t reduce ground clearance. Control arm drop brackets work fine, too, they accomplish the same goal. The Mopar extended length control arms are only $60ish for both, though.
Where did you purchase the Mopar control arms for 60+ dollars thank you in advance
liondor1969
marius
romania
jlu 2021
Hallo. Please help my..today i order this kit for my Rubicon JLU 2021..i must install correction barket or not ?
Because answer form aev ..is not necessary to install this:) Please tell my your JEEP work fine with not this braket ? Thanks from Romania !
