Advice for cleaning off mud?
T_Willys
Tyler
Baltimore
2019 Wrangler Unlimited Sahara
New Jeep owner, looking for input on cleaning mud and dirt off my Jeep, asides from power washing the undercarriage are there any parts to clean that may not be obvious? Also, is there any type of protectant spray you guys recommend using? Any related advice appreciated.
3VOLVE
Northern Virginia
2019 JLUR
Most important thing is to get whatever you can with just water. Crawl underneath and see what you missed and consider brushing of whatever you can with just water. Simple green or your favorite cleaner helps and rinse with water.
Remove any corrosion with some light sanding and spray with your favorite epoxy.
limeade
Guy
Reno, NV
I like to use an oscillating sprinkler (kind you hook to your hose) and let it run underneath the Jeep for awhile, changing positions to get the whole undercarriage. At the fore and rear of the fender flares there are openings, mud likes to get up in there. Spray up there really good until the water coming out is clear.
After a thorough undercarriage rinse, I like to spray Simple Green on the suspension components and either use a soft bristle brush or a sponge to get them clean.
T_Willys
Tyler
Baltimore
Is there a specific simple green bottle you recommend?
limeade
Guy
Reno, NV
I get the regular green simple green by the gallon and then pour it into spray bottles. For cleaning and degreasing, I use it full strength.
Goosed
Ohio
2020 JLUR
I always spray wd40 on my frame and under the Jeep before off-roading. Buy the wide mouth/wide spray cans. When you are done wheeling it makes mud a lot easier to clean off.
spurly
Zach
Nebraska
2019 Bright White JLUR
In addition to sticking a sprinkler under the body, I like to stick the hose inside the frame and clean everything out. I'll push the hose in through several holes from different angles to make sure I get it all. You'd be amazed how much crude they can collect. I also have the Ryobi undercarriage cleaner/sweeper, it works on, but I need a higher volume pressure washer for it to really work best.
WagzDad
Carroll
South Louisiana
You should not use simple green on aluminum.
You can put baby oil in a spray bottle and pretreat in wheel wells and underbody stuff that doesn’t get hot. Don’t use it on your paint
limeade
Guy
Reno, NV
My first reaction to no simple green on aluminum was WTF?? So I looked it up and you're right.....never knew that before. Simple Green says their regular stuff shouldn't be used on uncoated, unfinished, or unpainted aluminum unless a protectant is used afterwards. Apparently simple green will accelerate the corrosion of aluminum.
There are some simple green products safe for aluminum, but I haven't seen them at a store. Must have to order them directly.
Thanks for the info!
