Adjustable track bar for JLU yet?
Carlton
Chicago
Jeeps lots of jeeps
I installed the Mopar kit which came with the replacement front lower control arms. So I should save my money and not put new track bars on?
Track bars will center your axle but I don't think they will do anything for your steering issue.
TroyBoy
Troy
Vancouver Island, Canada
We have changed the bend profile on the front track bar since the original design, When we first came out with the track bar, there weren't any aftermarket diff covers to go off of so we went off the measurements of the stock diff cover plus some to account for the size we anticipated for diff covers. Give us a call at the shop and we will take care of you.
Lol, you already did quite a while ago. Thank you! :)
Rock Krawler Suspension
Tech Support
Waterford New York
rockkrawler.com
Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
Oh, did Jeremy handle that for you? I just now saw this... I must be behind the times... How is the new one working out?
TroyBoy
Troy
Works great and thank you guys for offering to fix this for me. I just assumed I would have to find something else.
Bigfoot
Kevin
Tennessee
2012 jku 2018 jlu
Installed the jl mopar 2 inch lift.
The front axle is off 3/4 and the rear an 1inch.
Going to get a front and rear adjustable track bar. Getting a floating feeling at higher speeds.
Hope this helps.
Any input to those that have this problem.
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
Hope this helps.
I still have bump steer / wobble with bad roads even with the track bars. Ordered a set of adjustable lower LCAs to extend the caster out further after talking with a few other users and metalcloak.
Carlton
Chicago
Jeeps lots of jeeps
For the people experiencing flighty steering after lifting, track bars aren't the way to correct it.
It is most likely a caster issue. Add a set of @RanchoShocks geo brackets. They not only correct caster, but level the arms to improve ride quality. They work much better than adjustable arms imo.
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
For the people experiencing flighty steering after lifting, track bars are the way to correct it.
Don't they reduce clearance though?
Carlton
Chicago
Jeeps lots of jeeps
A bit. If your jeep is a dedicated rock crawler, lower arms may be better if you are worried about hitting them on the rocks.
If it isn't a dedicated rock crawler, the on road improvement is worth it. I have had lifts with adjustable arms and kits with the brackets. The brackets result in a much better ride quality due to leveling the arms in addition to correcting caster.
I was always a proponent of adjustable arms until I tried the brackets.
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
Interesting. Well I just ordered a set of LCAs so I'll have to stick with that.
TJEli
Eli
MI
Jeep, truck, car
I think you just misspoke here because the second part of your post is correct. I have never seen a track bar cure a steering issue unless it was loose or the bushing were worn. Track bars adjust thrust angle and really don't effect the way the steering "feels".
-Eli
Carlton
Chicago
Jeeps lots of jeeps
-Eli
-Eli
Oops phone changed aren't to are. Track bars will not help the issue.
Tech Support
Waterford New York
rockkrawler.com
Lower arms will be a big help for sure. Squaring the axles with track bars or track bar brackets would help if you noticed your Jeep dog tracks down the road.
RK
jeremyjeep
Jeremy
Jeep, USA
JLUR
-Eli
1. If the bushings in the track bar were worn could it cause excessive play in the steering wheel (1 to 3 inches of play in the steering wheel before the tires turn)?
2. Is there any other malfunction in the track bar that could cause excessive play in the steering wheel? Like 1" or more of deflection in the track bar. Assuming the bolts are tight.
trpp_35
Tripp
Tampa Fl
2018 Jeep Wrangler JL Unlimted Sport
I remain interested in what's available for our lifted JLs. Seems like ever since I installed the Mopar 2 inch lift my steering has been flighty, constantly having to make adjustments as I'm driving to continue tracking straight. I don't remember my steering being this awful on my lifted JKs. Anyone else experiencing this? I'm open to suggestions and hoping new track bars might fix the problem.
I have been having the same issues but it doesn't sound like mine is nearly as bad. I have been told it could be the cam bolts and I have also been told to look into the lower control arm geometry correction brackets, but I do think it has a lot to do with my track bar as well.
