bjeepz
Regarding control arms when going a bit taller on the XR package or any Jeep, just doing rear lowers is not a good idea, I found this out when I did this after bending a rear arm on my JK, it created an even worse pinion angle and driveshaft issues, so I had to had rear uppers to correct this problem.
Up front geometry brackets are a cost effective way to get a proper driving feeling and pinion angle correction, likely not as perfect as properly adjusted arms.
As for the driveshafts needing replacement this is also related to extended shock length, I forget the exact number up front but is it in the 29in range.
When I had my Rubicont XR I added the Mopar lift front sway bar links as I didn't like the look of the sway bar angle when electronically disconnected.
I got back into a Mojave and am now back in a JLU, but a Willy's XR this time, I run a 1 inch spacer up front and Falcon 2.1 shocks for 2-3.5 inches of lift, the rear links are fine. I need a front solution and hope to go with the Antirock setup.
Next change will be the Mopar front lower arms, they make a positive difference with the 1 inch spacer in my experience.
