Sting_NC_USA
- Michael
- Mar 25, 2018
- Birmingham, AL
- 2018 Jeep Wrangler JL Unlimited Rubicon
- Build Thread
- Link
- Vehicle Showcase
- 1
[/QUOTE]
The missing ingredient in the setup described is that you're not using a LOC/DSP device. With the resistor method described in Post #1, something in the class of the JL Fix86 is used. In this configuration, the wires with the resistors coming from the radio typically feed directly into the LOC/DSP which (after being calibrated) processes the signal and conditions the sound that's passed to the AMP using RCA cables.
Running the wires, as you've described, directly into the AMP's inputs, really isn't advised. The tolerances are not tight enough that way to consistently "fool" the radio's Ohm test.
Having never installed a system using a pure resistor approach without an LOC/DSP, the sketchy playback experience you're describing leads me to believe there could possibly be loose connections in the harness. Or, more likely there may be some sort of resistance change by using the harness. It's really, really hard to determine.
I do think you should consider the PAC and ditch the resistors, or keep the resistors and pick up a LOC/DSP similar to that which I and others have recommended. That's probably, not what you wanted to hear, but I believe it's important to share what will lead to the best outcome. Best of luck!
Interesting result.Hey.. sting_nc_usa
I need some help with basic 7inch radio with alpine ktp 445u. I followed the way to hook up the with radio with resistors , of course . I got t harness from clutchfield and i modified to work with the alpine amp . Here is the problems after i finished install no sound so i check dip switch . After that only front right side speaker got sound . Only two times suddenly all the speakers make sounds . But now , only one speaker is working .
i changed dash speaker and soundbar speakers with infinity speakers.
What should i do ? I dont wanna buy pac , i just make all speakers to work .
Thanks so much .
