SnowBall
NAY
El Centro
22' JL 2 door 3.6 V6 Automatic
Hello, I have a question I have a 22' JL 2 door V6 8 speed Automatic, and I recently did a lift kit of 3" and 33" tires. I noticed that the jeep is not changing gears how it should from 4 to 5 my RPMs go to 3.5 and it will not go into 8th gear. I wanted to know if a tazer like a Z Automotive programming tazer would fix the issue. The dealership wants to charge $350 just to do gears but a tazer can do much more for about the same price. Can anyone let me know if they liked the Tazer and if they recommend it. thank you
yokramer
A Land of Petty Tyrants
Snark Incarnate
If I could go back and do it over again I would have went J-scan over tazer
siggy
Kansas City, MO
Fun ones!
JScan might be the better route. To me the only feature that JScan can’t do that’s valuable is disabling auto start/stop (easily).
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
There are features the mini does that make it easy to perform while driving... and a few more jscan does not do... like security lock, and window roll up/down when locking / unlocking doors. The lite version, jscan can do as given in previous reply
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
I have a tazer and use a decent number of its features. I haven't changed tire sizes yet, but the tazer will adjust the speedometer and shift points for the changes you made. It's very easy to use once you get the hand of going though the settings. It's also nice being able to set the jeep back to factory (the tazer saves your settings) for when you bring it into the dealership. No idea if the Jscan does that.
Edit: Looking into it, they both can give access to using the hood alarm which is a GREAT security measure. Why Jeep doesn't have it from the factory truly baffles me.
Grayhound
Michigan
Jlurd
The tazer does onetouch windows and key fob windrow control!?
KLMkrieger
Keith
2020 Rubicon JL
If I could go back and do it over again I would have went Superchips FlashCal+ over tazer.
SnowBall
NAY
El Centro
Very good information am going to look at those brands too some of the important things I do want to control is
*hood alarm
*3 hooks when leaving the car on
*tire size
*gear ration
*start/stop so fucking annoying
*and I just saw that z automotive has a code sequence that has to be inputted before driving I love this because I live next to the Mexican boarder and its more protection to prevent theft.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Don't forget about the Tazer's ability to increase how fast you can go with your sway bar disabled (for Rubicons), turn assist, being able to use HomeLink for a while after turning off the Jeep, etc.
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
i cant get J-scan to work for crap on my jeep.. Ended up just using the Tazer
SnowBall
NAY
El Centro
am going to have to look into ( turn assist, being able to use HomeLink for a while after turning off the Jeep ) I haven't heard of these
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
I wasn’t aware of the HomeLink option. I don’t know what the heck Jeep was thinking setting it up the way they did. One more reason to add the Tazer to the wish list.
Ratbert
PNW
Software Engineer
Having it shut off with the vehicle makes sense from a safety perspective. Every other vehicle I've owned does that. Tazer lets you make that decision yourself with the option of keeping it alive for a bit based on a timer.
Dusty Dude
Agreed. My Challenger is on all the time, which I thought was stupid. On the other hand, having it on for 30 seconds after shutting off is much better than shutting off immediately with the key. They keep the headlights on for a set time after shutdown, why not the Homelink as well?🤔
