Added Mirror Turn Signals
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
Finally got the new caps and turn signals on, and expanded the project a bit with some Baja S2s, amber marker lights below the Bajas, and white markers under the mirror as a puddle/courtesy light. Hardware installed today, still need to wire it all up.
woah. That mirror has a lot going on
3VOLVE
Northern Virginia
2019 JLUR
Also the Euro-spec mirrors have different convex areas than US-spec, they both have convex areas on the outer parts. I found this gives a huge improvement in visibility on the driver's mirror especially.
Great idea and thanks for sharing. Iā€™d also be interested to learn more about the convex areas and the improvement in visibility. Can you share more info on this and your perspectives? Also wonder if their is a separate part number for just the mirrors, heated and unseated. Heck, the $300 might be worth it on the improved visibility alone.
Daffydnbugs
Illinois
2020 JL Wrangler RUBICON
Might be an odd question but would you happen to know the screw size to attach the turn signals to the caps? I have all the parts but those and thought maybe I could save some time going to hardware store and buying different sizes if I could find the answer.
bgrex
NJ
JLU Sahara Altitude - Sting Gray
Unfortunately not sure on the exact size. SInce the signal lights annoyingly didnā€™t come with screws, I had to just rummage through my workbench ā€˜junk drawerā€™ to find 4 random small (maybe 3/8ā€ or 1/2ā€ long) pan-head philips wood screws that worked.
Daffydnbugs
Illinois
Same here, no screws, thank you though.
sentience
Maryland
2023 Lexus GX, 2021 JLU Sahara 4xe
bureaucrat@gov
Very cool. Nice job!
But, why did I read this? Now my OCD is going to kick in and Iā€™ll need to order a setā€¦
Daffydnbugs
Illinois
What did you use for the puddle light?
bgrex
NJ
Cheap leds from Amazon: Partsam 3/4ā€ smoked lens white led marker grommet light for the puddles (same light but in amber for the front-facing markers that will tie in with the fog lights). Theyā€™re not super bright like a set of rock lights, but good enough to see the side steps and any puddles when entering/exiting.
Jeep Wrangler JL Added Mirror Turn Signals 2E29377F-ABCD-4549-B457-0564E2D914DD
weeitsmikelee
Durrty Jersey
ā€˜21 Wrangler392; ā€˜20 F-Pace; '15 XL883N; '82 CX500
Healthcare
JeepRealtor
West Bloomfield, MI
2019 Jeep Cherokee Overland
Also hoping for the right screws to mount these leds to the mirror caps if anyone has found part numbers or know what will work good. Thanks!
Teneski
Teneski
Middle Tennessee
'19 Unlimited Mojito MOAB
Entreperneur
Do the Baja's interfere with the power mirror? I though the Baja was 3+ inches in depth or is the replacement cap with the turn signal larger? Also are you happy with the light veering off to the side like that? was that your intention? Have you completed the wiring? Any pics posted all lit up? Anyway it looks good. Great job!
Solo25
Ohio
21 JLURD, 22 JLUR4XE ON ORDER
This right here with the Baha is exactly what I have been wanting. I didnt know if there would be enough room to add a light in these compared to the caps from a JK that come with lights already. Looks great!!
Teneski
Teneski
Middle Tennessee
Entreperneur
Otherwise it went pretty smooth installing
Hello Jon, This is a simple and a great mod for just over $100. For the side lights I ordered ( they haven't arrived yet) it appears it takes plug to connect the circuit. I see you have a plug in one of your pictures. May I ask where you got it? (plus part number)
Wbino
NJ
2021 Wrangler JL H.A. -- 1999 SLK 230
Does having the ASG complicate the possibility of adding the side marker lights to my mirrors?
