5000 lbs tow limit
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Rough country doesn't list specs, but does classify their hitch as class 3. By industry standard class 3 hitches are supposed to be rated up to 8klbs. Has anyone seen the hitch installed on the European and Australian models? They've always had a 5500lb rating so I'm guessing they don't put the class 2 hitch on them?
I remember it also being difficult to identify actual hitch ratings on my Ram. It's identified as a Class IV on the window sticker, but the only thing I was ever able to find was a max tongue weight listed on the tow guide.
I cant find a wrangler tow guide, There is a crappy tow info link I was able to find on Jeep's site that has some info:
https://www.jeep.com/hostc/towing/basics/trailerWeight.do
Jeep Wrangler JL 5000 lbs tow limit 1699459235219
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
Zandcwhite
Zach
Patterson, ca
2019 jlur
You would only want to tow at 80% of your capacity anyway. 5K lbs is heavy for a vehicle that only weighs 4,600 lbs.
As opposed to the 6,200lb tow rating of the 2001 grand cherokee that weighed 4k lbs? The 10,500lb tow rating of my 2017 ram rebel that weighed 5,800lbs? The new 3500 diesel trucks that weigh 7,500lbs and have tow ratings north of 30klbs? The 60klb trailer behind your average semi that weighs 15klbs? A trailer that barely outweighs the vehicle is far from heavy towing. The JLU has been rated at and safely towed 5,500lbs in Europe and Australia for 5+ years. Their testing isn't quite as stringent, but the cooling system is the biggest thing holding down our tow rating in my opinion. Jeep practically admitted that when they got the JT with virtually the same drive train, axles, and vehicle weight rated up to 7klbs by opening up the grill. Marketing will have you believe the rating increase is a result of the new full float axle, but the non-full float in the JT can handle double the load of the JL? I call BS all around.
KCSgtMaj
Andy
KC
Frame strength, wheel base suspension among other things all factor into what a vehicle is capable of towing. European standards have nothing to do with it. And you can’t compare an OTR tractor/trailer combo to a Jeep Wrangler, or a full size pickup. It’s not the same math. And who’s dragging a 5K lbs trailer in Europe with a wrangler?
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
PICK YOUR POWERTRAIN
Jeep® Wrangler delivers power and efficiency thanks to a choice of four available engines. Choose the heart of your Wrangler.
PHEV WITH 2.0L I4 DOHC DI TURBO ENGINE
3.6L PENTASTAR® V6 ENGINE
6.4L HEMI® V8 ENGINE
2.0L TURBO ENGINE
Jeep Wrangler JL 5000 lbs tow limit y-Engine-2.oL-Feature-Panel-Desktop.jpg.image.1440
A LEGENDARY ENGINE
Paired with either a manual transmission or automatic transmission, the legendary 3.6L Pentastar® V6 engine with Engine Stop/Start technology provides impressive efficiency and reliable power. Engine mpg ratings based on two-door models. Towing rating based on four-door models.
UP TO MAXIMUM HORSEPOWER
285
UP TO LB-FT OF MAXIMUM TORQUE
260
AUTOMATIC TRANSMISSION WITH STOP/START UP TO MANUFACTURER ESTIMATED HWY MPG
24( Disclosure6)
MANUAL TRANSMISSION WITH ENGINE STOP/START UP TO MANUFACTURER ESTIMATED HWY MPG
25( Disclosure7)
UP TO MAXIMUM TOWING CAPACITY (LB)
5,000( Disclosure 8)
(8) See Dealer for details
Zandcwhite
Zach
Patterson, ca
2019 jlur
Frame strength...gc was thin sheetmetal unibody. Wheelbase...gc is ~10" shorter in that regard. Suspension...gc was basically a tj front Suspension, had smaller brakes, and weaker axles, etc. Very familiar with both vehicles as I've wheeled and modified both over tens of thousands of miles. Regardless of rating I would gladly tow more with the jlu and it would be safer and more controlled. You do realize that people on Europe and Australia pull trailers, camp, and wheel too right? There are thousands of people who have been towing up to 5500lbs with their JLUs for 5 years. It's our steep uphill grade in 96⁰weather requirement that set the JLU limit so low in my opinion, although that doesn't explain the full float axle bumping it up to 5k. Axle failures would be prevalent if it was at all the limiting factor as European models get the same axle, and they simply aren't. I'm not telling you to go hook up a 5klb trailer, but if I needed to I wouldn't hesitate to say bob's your uncle or g-day mate and go for it personally.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Zandcwhite
Zach
Patterson, ca
2019 jlur
Which we know is erroneous. Nobody has seen one with a Class III hitch.
I still want to see what hitch they put on European models. It can't be the class 2 with 3500ln rating and then they all just tow 5500lbs.
garykk
Gary
Southern NM
2022 JLURD
class two hitches are 1 1/4”. Jeep is 2”.
Jeep Wrangler JL 5000 lbs tow limit IMG_0177
GATORB8
CLT NC
Its a 2” class 2. Listed as class 2 on all the Jeep info.
Jeep Wrangler JL 5000 lbs tow limit 1699538061301
