4LO and Brakes
roaniecowpony
Retired Engineer
Have you done an ABS bleed?
The process of ABS bleeding involves regular system bleeding, then activating the ABS bleed mode with a JSCAN, Taser, or similar while bleeding.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
This is weird. 32 degree down slope on Fins and Things and the brake held me just fine and I was in 4lo 1st gear manual mode. I agree with others you got an issue with your brake system.
roaniecowpony
Retired Engineer
Have you done an ABS system bleed?
Medsker
Jon
South Jordan, Utah
Retired Engineer
I've done the abs bleed 5 times now and bled the brakes after I did it.
Medsker
Jon
South Jordan, Utah
Retired Engineer
Sorry, I feel like I'm stealing the thread. OP, let me know if you want me to start a new thread. I just figured it can help both of us.
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
What about the Off Road+ buttton? I usually hit it when I drop t9 4LO but I’m now wondering if it is applying the brakes at times.
What exactly does that do?
If I'm understanding its description correctly, "Off Road +" has four major functions:
1) Changes transmission shift points
2) Changes throttle / gas pedal mapping (more aggressive 4H, less aggressive 4L)
3) Allows rear locker to be engaged in 4H
4) Reduced 'Traction Control' function
To me it sounds like a problem with the ABS, either something not functioning appropriately or possibly a leaking solenoid.
Have you tried a 'Full Off' of the ABS/Traction Control/Stability Control function?
(That is, at a complete stop, press and hold the TCS button for 5 seconds until you hear a chime and get a dash message).
LF
AZ Hella
Sonoran Desert
JLUR
In 4LO the off-road+ button activates aggressive BLD action.
AZ Hella
Sonoran Desert
JLUR
Once in Off Road+, the vehicle will begin to behave in different ways depending on the 4WD mode in use. The following enhancements will occur when using Off Road+.
4L (4WD Low)
• Engine/Transmission Calibration: Rock Crawl and controllability focus, change in shifting schedule when rock crawling, pedal calibration shifted to de-gain and low range, operates at lower vehicle speeds
• Traction Control: Aggressive brake lock differential tuning at slower speed or FIRST gear • Off Road+: Recall the last status between ignition cycles.
Caymanedge
Caymanedge
North Coast
2020 JLUR
4L (4WD Low)
I’m pretty sure when I activate the Offroad+ it tells me it disables the traction control. It definitely controls the brakes. I can hear the drivers front caliper/rotor working at a hard left turn. So that could be the overheating issue experienced in the past.
I guess an ABS bleed is in order to eliminate that potential issue.
I will also leave Offroad+ off unless necessary. I had the habit of just activating it when dropping to 4LO.
When running in 4LO I always manually shift, using the brakes minimally.
heading to Elephant Hill tomorrow…..
AZ Hella
Sonoran Desert
JLUR
I use it all the time as well and have never noticed a problem.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
So I hate my brakes when off-roading in 4LO. Pedal goes all the way to the floor and on steep declines barely holding on.
I had some brake fade last year after a long day on the Rubicon but this is different, I have bled all the fluid and upgraded to a higher temp fluid.
It almost feels like the brakes are going on and off when in 4LO. I can hear the rotor grab screech at times.
Anyone experience this!
I had a similar problem and what it turned out to be is air in the ABS system.
A normal brake bleed WILL NOT remove the air trapped in the ABS.
You will need to do a ABS bleed to remove the air.
Here is a video that explains and why.
One note. Do not buy the autel scanner. There is a yearly subscription you have to buy for it to work.
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
While it is normal to require high brake force in 4low, and torque converter automatics can sometimes overdrive their brakes depending on axle gearing and toque converter stall speed, your description of the pedal going to the floor is alarming.
I have had spongy brake issues that could not be solved until I got an ABS bleed at the dealership. I would recommend you do the same. My service writer only charged me half an hour of labor for this.
