3rd brake light (CHMSL) no power
spoon359
Marty
Mississippi
2018 Jeep JL wrangler Sahara
2018 JL Wrangler Sahara
The light is good but has no power going to it. I’ve checked wires and connections back to where they go into interior wall inside cab by right rear tailgate and wires are good. Other tail lights, turn signal, brake lights all work perfectly. Can’t find a dedicated fuse for just the 3rd brake light. Any ideas will be greatly appreciated.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Did you use a multi-meter to confirm there is no power to the 3rd brake light?
Flip
Johnny
Virginia
I'm wondering if there is a separate fuse just for the 3rd brake light?
This is the tool I use; I would start from the 3rd brake light and work my way back. Find out where that wire has lost power. Also look to see if you can find the ground for the 3rd brake light.
Jeep Wrangler JL 3rd brake light (CHMSL) no power 51dijQeXhxS._SL1000_
Heimkehr
Pennsylvania
2021 JLU 2.0T
Prior to observing that the CHMSL wasn't illuminating, were you doing any work on the rear of the vehicle that would've required unplugging the connector on the underside of the light? The pins are small and fragile, and thus easily bent if not taking proper care when buttoning things back up.
Otherwise, manually trace the wire(s) as suggested in the preceding post.
spoon359
Marty
Mississippi
I’ve traced them to where the wires go in rear right wall. So I’ve gone as far as I can without tearing the interior out of it. I haven’t taken anything apart until I pulled connections on wires apart to check for power. The pins looked good
Flip
Johnny
Virginia
Tracing wires can be a pita! I can't speak for my new wrangler yet but I'm usually pretty good at it. You have to really get into it, trace that little rascal down, think of the feeling of accomplishment, Victory will be yours! Time & patients, you can do it! ?
Jeep Wrangler JL 3rd brake light (CHMSL) no power hes-beginning-to-believe
  • Like
Reactions: GtX
Heimkehr
Pennsylvania
2021 JLU 2.0T
Absolutely, which is why I was asking questions before recommending that the OP continue doing so. It's not advice that I give lightly; I've owned three British cars and have paid my dues in that regard. ;)
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Pardon my candidness.
Just wondering how did you test the bulb was good?
Also, someone needs to step on the brakes for you to test if there is power going to the third brake light.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
There is a fault circuit. I bet you have a short somewhere. It won't trip a fuse.
I had something similar when I relocated plate and ran plate light off of right tail light. I had twisted new plate lightnLED and it was shorting out causing the running light portion of my tail light to not work.
Baba Yaga
NJ
www.youtube.com
Retired LEO
OP said he never touched any of the wiring. If its not a corroded ground, it has to be the bulb. Just my $.02. ;)
Dyolfknip74
2021 JLU Rubicon
You can have a short without touching wiring.
I have LED package, not sure if the middle light is LED on all models but if it is, a faulty LED is possible but doubtful. OP really needs to confirm it.
Flip
Johnny
Virginia
OP said 'The light is good but has no power going to it."
He said he checked the wire connections at the 3rd brake light with a multi-meter and there is no power.
I'm not familiar with a fault circuit. I would definitely check that, where is it located?
Baba Yaga
NJ
www.youtube.com
Retired LEO
Yes. I'm tracking what the OP posted, but.....how does he know the bulb is "good" and "no power is getting to it" There is no power going to my third brake light until I step on the brake and bulbs may look good unless you run an isolated power source to it.
Again. It's just my take that grounds and bulbs go bad before wire harnesses if nothing has be disturbed. I was just trying to save the OP from ripping out his interior. I'll stop then. ;)
Best of luck to the OP.
