392 Aux Fuel System Complete
SteveSRT
Sparks, NV
GMC Denali, wrangler
That looks really cool. I want to see it mounted on the back of a jeep though. It seemed dumb they had a picture of the front of a jeep
kkarnage
2022 392, 2020 JLUR, 2015 JKR
Interesting, thank you. I suppose you could uninstall the tailgate reinforcement bracket anyway. Not like we're using it.
I'm going the AEV Fuel Caddy route on mine when it arrives. I had a Mopar tailgate reinforcement that I fitted to one of my previous Wranglers, and looking at some pictures online of it now I don't think it would be a problem to grind it off though instead of removing the entire thing.
The challenge with removing the entire thing is that the bolts are not going to be body color (unless your Jeep is black), and *may* be too long. If you can get a set of normal length bolts and body color them, then removing it might be an option.
guarnibl
Scottsdale / Sarasota
'09 JK, '26 Willys
Hmm... didn't think about that. So you'd be left with a visual eyesore without the tailgate reinforcement that would require a body shop to touch up. I'm sure stock bolts are available from FCA.
kkarnage
I'd be surprised if the area under the reinforcement wasn't already properly sprayed body color and all, but yeah, there are going to be marks on it where the reinforcement touches it, and potentially slight rubbing as everything flexes.
Stock bolts should be obtainable, yeah. You'll have to paint them yourself though I suspect.
What I'll probably end up doing is just gaining that antenna mount off and painting the cut area black again.
nismo1013
Winter Park, FL
2023 JL 392 AEV370
Any update on how this turned out?
W3XPLOR
AZ
392 XR, JKUR's
Reviving thread to see if anyone has made the AEV fuel caddy work with XR carrier or found a better way to carry 10+ gallons of fuel?
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
I wish I could say yes, but no not at all. I added a RotoPax for 5 gal, that's my only extra for now.
2nd 392
Ca
There is an older thread where someone got an LRA aux tank to work on a 392. But it required extensive exhaust modifications that cost nearly as much as the tank.
