37s on xtreme recon package?
azbikerguy
Mesa, Arizona
2022 Wrangler Rubicon Unlimited XRecon
I have the metalcloak 3.5 gamechanger. That was mid mods lol. 4.56s is ok for 37s I would prefer 4.88s but that's not enough of a change to regear. Remember it's a 4:1 case you are very low off road
Did you keep and use the OEM wheels? And have you tested this setup in challenging offroading?
azbikerguy
Mesa, Arizona
Stock wheels, 39s, 3.5" metalcloak springs, run John Bull and Holcomb creek without even getting out to spot. You could say it works pretty well.
Wow. 39s on the OEM wheels. Didn't know that was possible.
Sounds like 37s on my OEM wheels with my 2.5" lift would work well.
Don't know those trails. But did Back Way to Crown King. Fun trail.
Jtphoto
Thunder Bay ON
I just changed up to my second set of 37s on factory wheels. Gonna try out these Yokohama Geolandar MT G003 37x12.50x17.
Jeep Wrangler JL 37s on xtreme recon package? IMG_0920
Jeep Wrangler JL 37s on xtreme recon package? IMG_0922
Jtphoto
Thunder Bay ON
On a side note. My tire guy couldn’t mount these tires on my XR rims without taking the rock rings off. The bead protector on the tires were too thick and heavy for his machine. This is the 3rd set of tires he has put on for me but the first time the rings had to come off.
azbikerguy
Mesa, Arizona
They are on now, in the photo. Did you put them back on or did he remove only to install, then put them back on?
I will likely use Discount Tire. They have done well for me in the past.
Jtphoto
Thunder Bay ON
He removed the rings, mounted the tires, re installed the rings then balanced the tires.
gato
New England
2021 JLUR
Hey do tire chains have any issue mounting a 37x12.5 on these 8" rims when most or all tire manufacturers list 8.5" as minimum rim width for this size tire?
(I live in such an overly regulated and offroad unfriendly area - just a see of conforming mid-size crossovers - and the tire shops have all these weird rules)
Thanks.
Retired Jeeper
Dwain
Illinois
2020 Grand Cherokee, 2014 JKUR, 1967 CJ-5
You can certainly run 37's on a JLURXR with little modification. My Jeeping buddy runs 37x12.5 MTs on the stock wheels. He's made the following modifications to make it work. 1' spacers in the front, 1/2' spacers in the rear, added about 1.5' bumpstop in the rear, and put on some Bilstein 5160's that provide added droop. While we don't do extreme trails as we drive our Jeeps to/from the trails, we've not shied away from some challenging trails in CO, WV, SMORR, Maine, etc.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Thanks.
To be honest I don't know. As a small town guy I try to avoid chains where possible and tire shops seem to be one of the few mom and pop shops that are still around. Both local tire shops have never batted an eye and we ran 37x13.50s on stock 7.5" Rubicon wheels on our 2019. The tire guy complained about wrestling the 39x12.50s when he mounted those on the xr but so do I every time I do a tire rotation.
