37" tires on XR
Yossi
Yossi
Israel
Rubicon
Hello freinds
For increasing wheels of XR to 37" do I need to reinforce the axles?
yokramer
Snark Incarnate
a 37" wheel even in Aluminum is gonna be HEAVY so yea gonna need to beef up a lot of stuff ... the biggest issue will probably be finding a tire tho.
1BadDad
Zach
Tulsa, OK
2021 JLURD, 2023 JLURD
IT Innovator, Thought Leader
Whew! Tough ask. Usually you’ll want to run a 44” or greater tire with a setup like that. Tractor supply may have what you’re looking for.
yokramer
Snark Incarnate
Gonna have to spring for $10,000 Carbon Fiber ?
Hell maybe even 10gs each wheel with that size. Gonna probably need to run a 17.420 gear ratio in the axles too.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Hello freinds
You’re gaining a lot of attention by asking about wheel size when it seems you’re probably looking for tire size.
If you’re asking about 37” tires, you should be fine if you’re reasonable with the skinny pedal off road. Here’s Jeepeto III on XR wheels and 37” Yoko G003s and KMC Machete beadlocks with the same 37” Yoko G003s
Jeep Wrangler JL 37" tires on XR AA709201
Jeep Wrangler JL 37" tires on XR IMG_6320
kah.mun.rah
Merenkahre Jr.
Duat
It all depends on how you dive it. You can break an axle with 30" tires hitting a bump with enough speed and on the other hand there are those who run 40s on stock JL axles without any problems.
Yossi
Yossi
Israel
Rubicon
If you’re asking about 37” tires, you should be fine if you’re reasonable with the skinny pedal off road. Here’s Jeepeto III on XR wheels and 37” Yoko G003s and KMC Machete beadlocks with the same 37sYoko G003s
Sorry, you are right my mistake, what I ment was 37" tires
yokramer
Snark Incarnate
I think mainly cause its a question that has been beat to death and some simple googling will give him an answer.
yokramer
Snark Incarnate
1BadDad
Zach
Tulsa, OK
We knew what you meant. We just never miss the opportunity to seize a funny moment. :) you’ve come to the right place for this question. You do not need axles or other modifications. I ran stock 392 wheels ( a tad narrower ) with a 2.5” lift and 37” Ko2’s without any issues at full flex. With the xr being right near 2” i would say you would see very similar results.
I have slammed mine on rocks, across tough trails, 13 BoH trails etc and never had an issue with anything driveline or clearance related.
Zach
