37” tires on stock Rubicon wheels
Ricmcd
Rick
Meridian Idaho
2019 JL Rubicon 2 door, 2006 TJ Rubicon
Semi-Retired Electrical Contractor
Ordered a JL Rubicon , 2 Door. 3.6 w/8speed. I’m considering putting the JKS 3.5 lift (net 4” on a 2 door), Fox 2.0 shocks and Stabilizer, Nitto Trail Grapplers 37/12.5/R17 on stock Rubi wheels. Anybody done this yet? Do the stock wheels work without rubbing? Do I need spacers? Will I need to replace the drive shafts?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I’m not speaking from experience, I’m an engineer and my math says it would fit without spacers. As long as you have the 4” lift you should clear it. However the consensus from reading the forums is that you probably should get a new DS.
Ricmcd
Ricmcd
Rick
Meridian Idaho
  • Thread starter
  • Thread Starter
  • #3
I’m not speaking from experience, I’m an engineer and my math says it would fit without spacers. As long as you have the 4” lift you should clear it. However from reading the forums you probably should get a new DS.
I do believe the height will not be an issue but I’m worried about the back spacing. JKS says I need 4.5-5” back spacing but does not specify a offset. Nor do they specify a wheel width. The Rubicon wheels are 17 x 7.5 which seems very narrow for a 12.50” wide tire and nowhere can I find the back spacing for this stock wheel. I was hoping I did not need to purchase new wheels...
Arterius2
Jerry
Vancouver, BC
I was talking about backspacing the whole time. No doubt you have enough height.
What I know from experience is that my Sahara can clear 11.5” tires no issue and Rubicon have 1.5” wider axles, so for a 12.5 tire, using my Sahara as reference you get 0.75” more of clearance inward to work with and 12.5 is only 0.5 wider than 11.5 inward so yep you will clear as long asthere is enough fender clearance. Which you do..
Ricmcd
Ricmcd
Rick
Meridian Idaho
  • Thread starter
  • Thread Starter
  • #5
Thank you, this is good info...
Arterius2
Jerry
Vancouver, BC
If my math is correct you can probably fit 13” wide tires without rub. But don’t hold my math to it if it doesn’t work out, real life is always a little more finicky. Heh.
Arterius2
Jerry
Vancouver, BC
Telling you backspacing is useless unless they tell you wheel width as well. 7.5” wheels have 4.25” of backspace at 0 offset. And less backspacing pushes the mounting surface inward and wheel hub outward giving you more room.
You can mount 12.5 tires on 7.5 wheels just fine they just bulge out quite a bit on the sidewalls like a balloon, but people have been running them without issues.
Ricmcd
Ricmcd
Rick
Meridian Idaho
  • Thread starter
  • Thread Starter
  • #8
Thank you, great chart, do you happen to know if the stock Rubi wheels are 0 offset or if not what they are?
Arterius2
Jerry
Vancouver, BC
I haven’t measured myself but there is a good deal of info here.
https://www.jlwranglerforums.com/fo...and-backspace-of-stock-jl-rubicon-wheel.3992/
Either-way a specific offset/BS difference should be multiplied by 2 to get maximum tire width to take advance of that given offset.
So.. if you were to gain 2” of offset you can essentially increase your tire width by 4” which I think is pretty excessive.. it increases the stance by giving you a wider look, but that’s about it.. looks.. doesn’t do anything for you technically speaking.
ATO4x4
