35's on 4.56 Gears
Oletimer
Darrell
Crystal River, Florida
23 ram 1500 5.7 , 24 392 final edition , 24 F150 5.0
Logging Contractor
Is the Tazer just for the speedo? Does mopar have 4:56 gears, or will they only go as high as 4:10 for factory spec?
Dealer did my 4.88 yukons in and its covered . I actually had a pinion failure at 3500 miles. They covered it all and gave me a lifted ram rebel to drive for a week.
Shantz
Shantz
Los Angeles
2018 Jeep JL Sport S
Producer
Just curious, how much did they charge, if you don't mind me asking? Did they flash your computer, or did you need a plugin like a tazer. I'm trying to keep it simple with no extra equipment if I don't need it.
Oletimer
Darrell
Logging Contractor
2200, they said they flashed it, but speedo is off by 4 mph at 60. So i dont think so.
Shantz
Shantz
Los Angeles
Producer
2200 not a bad price... I think 4mph isn't too bad either, I feel like they set the speed a little lower than actual from factory anyways... thanx for the info.
gpurp
North Texas
19' JL Sport 2dr
For those of you with the Sport did you have lockers installed along with the re-gear?
fdFifty
fdFifty
Pittsburgh
2022 Jeep Wrangler Rubicon
I did but only in the back. Ive been very pleased with just having the rear selectable. My $2k quotes only covered labor for the locker install.
Cracker_Box
Blake
Lafayette, LA
2019 Wrangler Sport S
If you have a manual transmission, I would definitely go 4.88’s with 35’s. Hope you get it figured out and really enjoying your Jeep soon.
Thanks for this input. I'm on 315/70's with a Manual and i have the 3.73 rear end. been trying to figure out what to do, it drives fine around town but its a dog on the interstate.
beaups
Sean
Ohio
2020 JL
hahha... oh yea, staying in 4th and 5th.
BTW which model got the 3.73's? I've only seen those on the diesels? I was under the impression USA was 3.45 or 4.10 on gas engines.
Cracker_Box
Blake
Lafayette, LA
the Antispin rear end is 3.73. or thats what i remember seeing it say when i ordered it. or im just thinking of my TJ... idk.
Shantz
Shantz
Los Angeles
Producer
AFAIK ordering a manual and/or anti-spin gets you D44, but still 3.45 ratio.
Yep, I have a manual, anti-spin, m220... it has the 3.45.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Which shop did you go with? I'm in VA I may go with those gears too...I have a jlus that I want to run 35s on
Granite Crystal Bandit
Houston
2020 Wrangler Unlimited High Altitude
Anyone running 35 inch tires with 4.56 gears? If so, are you liking that setup? Any major drawbacks on the highway?
I'm looking to re gear from 3.45's and I'm torn between 4.10's and 4.56's.
I went with 4.56s, and Nitto Ridge Grapplers (35x12.5x20). I have the 2.0T and the “zip” is back. Love the set up, excellent balance of power.
