3.0 MODS - Show em off
2020 Diesel JL
Peter
Debary FL
1955 CJ3B Diesel, 2018 Camaro Hot Wheels Convertible, 2018 Dodge 3500 Diesel, 2020 Harley CVO Tri Glide White, 2020 Harley CVO Tri Glide Black, 2020 Jeep Wrangler Rubicon Diesel
General Manager / Owner of CraneWorks Orlando
Do you have a pin of your powder coat oven? I too made one a couple years ago. Used about 2300 pop rivets! I hadn’t yet made the door when this pic was taken.
You can get these cabinets in a lot of different sizes. They are not cheap but will save a lot of time.
I just bought 2 acres around the corner from my house and will be meeting with builder today. They kids are gone now and I have a 3500 sq ft house. the new plane is 2300 sq ft house and a 3500 sq ft garage.
Megatron JLU
Anibal
TX
2020 JLUR 3.0 T Diesel
kosinar
South Carolina
2020 Black JLUR 3.0 EcoDiesel received 3/6/20
Megatron JLU
Anibal
TX
Looking great. What winch plate did you use? I got the same tires on KMC 235. Is this lift tested with 3.0l diesel?
Thank you. The lift is not tested on the diesel, we'll see how it goes.
I used this one:
Jeep Wrangler JL 3.0 MODS - Show em off 7AAB7C79-6082-44A1-8FB2-C676C8E1DF62
roll
lance
mississippi
vw tdi
I used this one:
I put an untested Tera Flex lift on my diesel. I had to add a 1 inch spacer in front. Rides great. Better than stock. I originally bought the Falcon 3.3 Sp shocks but the right front would not fit because of extra battery. I ended up putting Falcon 2.1.
Megatron JLU
Anibal
TX
Was it because of the reservoir? These fox shocks reservoirs mount separate from the shocks
Jeep Wrangler JL 3.0 MODS - Show em off CA0DA2D1-5A5C-4409-A7C2-40883786FF87
Beestmode
Travis
Fairview, NC
2020 JLUR Diesel
Couple of mods, waiting on parts for the lift.
37" Cooper's on kmc xd232's.
Motobilt tire carrier and license plate relocation bracket.
Warn 10s platinum winch
Lift will be a 3.5" Evo enforcer stage 4 with Fox 2.5" shocks.
How do you like those Coopers? I'm between them and Nitto Ridge Grapplers
roll
lance
mississippi
vw tdi
Megatron JLU
Anibal
TX
It does, it's quite a pain to wire though. All the rear inside trims must be removed. And you lose your oem third brake light as their kit does not come with a relocation bracket for it. I made my own and mounted it behind, inside the wheel.
2020 Diesel JL
Peter
Debary FL
2020 Diesel JL
Peter
Debary FL
I used this one:
What Warn winch part number did you go with? I first ordered a WARN 103253 VR EVO 10-S then I seen a video showing that Warn make the same model that they say is JL ready WARN 89611 ZEON 10-S. From what I have read the 89611 has a different control lever that will not hit the OEM steel bumper. Amazon shows both not fitting the JL. I am getting confused and going to go broke. I ordered the 103253 then heard about the 89611 so I ordered that and tried to cancel the first one but Amazon won't cancel it. So now I have 2 coming this week. Then I get home from work and found that my wife ordered me a WARN 103253 VR EVO 10-S Electric as a surprise so now I have 3 different Warn winches due this week. what is the right one? :angry: See
