Klausvanwinkle
- Dec 12, 2017
- Venice, CA
- 2014 JKUR
Key phrase there is that you'd have gotten the V8. Without a V8 option in the JL, the Eco Diesel is your next best bet for Hemi-like torque numbers while still delivering 3.6 Penstar-like HP and 4cyl mileage. It seems like the best of all worlds and that's why I want it. Although, I might be singing a different tune when trying to find a diesel station.It WOULD be rated at 30mpg if they tuned it right. My wife's GC ecodiesel got 26mpg stock. The best we ever got stock was 27.1. If you are going to get the diesel, you will want to get it tuned to kill the EGR and eliminate soot build up. Without it, you can expect to spend a lot of money over time getting soot buildup cleaned. With the Green Diesel Engineering tune, we get 33-35mpg on long highway trips. Day to day driving gives about 21.5-23mpg. The tune disables EGR and a lot of other "clean" crap so the engine performs much better. The engine is a dog without the tune.
I think a lot of people are under the perception that the diesel is going to save them money. I think they will be shocked to discover that is not the case. I'm guessing the diesel is going to be AT LEAST a $4500 option and when you add $2000 for the auto transmission, it's pricey. The diesel also is more costly maintenance-wise as well. If you are someone who pays to have your oil changed, expect $150+ for oil changes as thats what most shops seem to charge to do it on the diesel. The diesel also uses DEF so you have to monitor its level. Its about $800 to get the engine tuned to make it last. Also, you'll find that not every Jeep dealership will be able to work on it. The dealership we bought ours from did not have a diesel mechanic so we had to go a bit farther if work is needed on it. I like the ecodiesel, but if I had it to do over again, I'd probably have just gotten the V8.
I agree that it probably doesn't save you any money at the pump unless you're only driving highway and find cheap diesel stations.
For me it's more about the added power and range. If it got 5mpg better on the trail, that'd extend your range by about the same amount as an extra 10 gallons of gas.
