2024 Willys Mud Flaps
Baltika
Alex
Long Island, NY
2025 Rubicon X 6MT 2 door Fathom Blue
I installed the weathertech for the Rubicon on my 2024 Willy’s 4xe they fit really well.
Can someone point me to the correct part number for these? Above. Not the ones below.
Jeep Wrangler JL 2024 Willys Mud Flaps 1738456297285-tk
embedded rock
In the path of a future Kentucky tornado
'24 JLUWX (traded) | JLRX for EJS'27? Let's see | CRF1000L, KLX300SM
My front mud flaps. Fab'd and installed last summer. Work well enough. No hits when wheeling in Moab and Colorado last September. They can be removed with some thumb screws.
Jeep Wrangler JL 2024 Willys Mud Flaps 1738459155254-ui
Jeep Wrangler JL 2024 Willys Mud Flaps 1738459207770-vt
Jeep Wrangler JL 2024 Willys Mud Flaps 1738459263391-9o
In this photo, you can see the dirt splash pattern. The flaps appear to block for the lower front door hinge. Photo taken near Imogene Pass.
Jeep Wrangler JL 2024 Willys Mud Flaps IMG_20240908_122848404sm
Oyster
Robert
Long Island
2024 Willy's
The 2024 Willys uses the Rubicon Highline flares in the front, a change from previous years. The Weathertech online application tool incorrectly shows the 2024 Willys front mud flap as part number 110097, the same as previous years. This part will not fit on the 2024 Willys. The correct part number for the front mud flaps for the 2024 Willys is the Rubicon application part number 110100. I tried installing the 110097 - failed and returned - and the 110100 - successful - on my 2024 Willys.
@Tarheel Will 110100 fit the front of the 2024 Willys if it has the factory Heavy Duty Rock Slider with Step Assist option?
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
The WeatherTech no-drill ones made for the Rubicon will fit. My 2024 Willys 4xe has the wider performance rock rails and the safety package, and after a lot of trial and error with other brands, those are the ones that fit on both front and back.
Oyster
Robert
Long Island
2024 Willy's
Ok cool @GinaC , thank you. Any chance you can share a pic of your rig so I can see what the mud flaps look like on the Willys?
GinaC
Gina
Newport, VT
Jeep Wrangler JL 2024 Willys Mud Flaps 20250501_155729
Jeep Wrangler JL 2024 Willys Mud Flaps 20250324_170850
Oyster
Robert
Long Island
2024 Willy's
@GinaC They look great, thank you. Did you have to cut the front flap for it to fit around the rock rails?
GinaC
Gina
Newport, VT
Nope, they are molded to fit both the large and small rock rails.
andrei
NA
FL
2023 JL Rubi
Weathertech, are they plastic or rubber ?
GinaC
Gina
Newport, VT
The are plastic.
My dealership put them on for me, so I may have misspoken when I said they were the ones for the Rubicon. The WeatherTech website now has a way to indicate if your Jeep has the safety package. That was the problem with mine.
Here's the link for the 2026 Willys. I didn't order them yet because I don't know when I'll take delivery of the vehicle and they only allow returns within 30 days.
https://www.weathertech.com/mudflap...ppackage=327-9189_Yes&wt_settype=FrontRearSet
Pismo61
Temecula,Ca
2026 JLURX
What does the safety package have to do with the mud guards fitting?
GinaC
Gina
Newport, VT
The rear end is bigger and the holes don't line up.
Oyster
Robert
Long Island
2024 Willy's
@GinaC Is this the Safety Package you're referring to?
Safety Group $1,395
Blind–Spot and Cross–Path Detection
Automatic High–Beam Headlamp–Control
ParkSense® Rear Park–Assist System
LED Tail
GinaC
Gina
Newport, VT
Safety Group $1,395
LED Tail
Yes, exactly.
