2022 model year changes- 4xe
CivilJeep
Charlotte, NC
2022 Rubicon 4xe
Engineer
(5) A better design for the charge level indicator.
Are you referencing the indicator lights on top of the dashboard? I've thought these are one of the best designs I've seen. What is it about them you don't like?
Chazdog
Charlie
Seacoast NH
'14 Honda Pilot for now
Electric option across the entire lineup including the 2 door
Black96z
Houston
2021 Rubicon 4XE, Tesla Model S
Machinist, Applications Engineer
I don't get why they made it so big. LEDs are tiny, they could have made that whole assembly not take up the whole dash pocket.
sethz
Seth
New York
2022 Wrangler 4xe
Couldn't agree more. They don't have to be on the inside dash at all. It could just be a illuminated ring around the charging port area or line this up along the top edge of the windshield close to where it meets the roof.
Echo4papa
2024 Rubicon 4xe
Success Engineer
Or just recessed into the pocket so you could still see but they didn't "ruin" existing dash pocket mods (letting you cover over it even if so desired).
Subhoz
Subho
GA
Land Rover Defender
I heard on the @Wrangler4xefans podcast that they are working on making the Max Regen setting a sticky option (once activated it will just default to that setting the next time until you turn it off). Hopefully that will be available by the time the 2022s roll out of the factory.
Other things I'd like to see are -
(a) More colors (Earl from the Gladiator Farout concept would be awesome) and
(b) Look at creative ways to reduce the weight of the vehicle - potentially a carbon fiber hardtop ,fender flares and hood, lighter ergonomically designed seats as well as replacing the hard plastic parts inside with hard wearing lighter weight materials.
tactical_gnr
Taylor
Denver
4xe Rubicon
If you install a mini Tazer, the max regen setting is mostly sticky. It stays on about 80% of the time.
Asterix2112
Vienna, Va
Wrangler 4xe
Adding to the wishlist - (1) Locked Charging port cover ( should open only by operating an actuator - electric or mechanical inside the vehicle or on the keys
Why would you want a locking chargeport cover? I see no need (and would be upset if there was one). Are you worried about people hooking a cable up, attached to a tube and then they suck the electrons out of your car? (I'm pretty sure that is not possible).
FloridaLarry
Larry
Boca Raton, FL
Rubi 4xe
IT Manager
Dash depth and windshield angle of the Wrangler aren't HUD friendly.
A simple test is to place your phone at the base of the windshield to see where the reflection appears. This gives you an idea of where the projector would have to be placed and what angle it would need to be oriented.
Mazda had a solution that they eventually gave up on, but might work for jeep...
Cjanak21
Charlotte, NC
2022 Jeep Wrangler Rubicon XR
Cyber Security Consultant
Wireless Carplay will not come until the interior refresh, which might be for the '23 model year. The Wrangler had an interior refresh after 5 years in the JK and I think the TJ. They will have to put in a Uconnect 5 system for wireless Carplay, which would require a new center stack. I think that for '22 we will see a quarterly price increase, and only changes in available colors. Maybe some general changes for Wrangler, but nothing for 4XE particularly. Then I think there will be a technology refresh for '23 with the interior refresh. If anything for '22, they might add Offroad+ for the Rubicon.
There’s already an Off-road+ for Rubicon’s 2021 models and up
sethz
Seth
New York
2022 Wrangler 4xe
I am not worried about someone stealing power ..... which would require quite the hack and not quite worth the effort unlike siphoning gas off a car lol. But I do worry that some goofball vandalizing the charging port that's all.
Black96z
Houston
There is no Off-Road+ on the 4XE....
What exactly does it give the gas powered versions? I think you can lock the lockers in high gear?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Once in Off ROAD+, the vehicle will begin to
behave in different ways depending on the 4WD
mode in use. The following enhancements will
occur when using Off ROAD+.
4L (4WD Low)
 Engine/Transmission Calibration: Rock Crawl
and controllability focus, change in shifting
schedule when rock crawling, pedal calibration
shifted to de-gain and low range, operates
at lower vehicle speeds
 Traction Control: Aggressive brake lock differential
tuning at slower speed or FIRST gear
 Off ROAD+: Recall the last status between
ignition cycles
4H (4WD High)
 Engine/Transmission Calibration: Improved
sand performance/ wheel slip focus, change
in shift schedule for sport mode, pedal calibration
set to aggressive, operates at
elevated vehicle speeds
 Traction Control: High wheel speed, slip
tuning brake lock differential with no engine
management
 Electronic Stability Control: ESC Off with
unlimited speed
 Off ROAD+: Will default to OFF between ignition
cycles
Cruise Control and Adaptive Cruise Control
(ACC) will not function while using Off ROAD+. A
dedicated cluster message will display
indicating this if either feature is activated while
in Off ROAD+.
If the ESC OFF button is pushed while in Off
ROAD+, the following will occur on the vehicle:
 Push of the ESC OFF Button: Traction Control
will turn off, but Stability Control will remain
active.
 Hold the ESC OFF Button for five seconds: Traction
Control and Stability Control will turn off.
Billet4xe
Nowhere
Rubicon 4xe
That's called a combiner HUD. There's still practical limitations in how far up into the driver's field of view you could project the image. The further you get from the hinge point of the combiner, the more susceptible the image is to vibration. A shaky HUD image is highly distracting.
Franklin
SE CT
'21 Sahara 4xe Ordered '18 Tesla Model 3 For Sale
My wife has a Mini Clubman JCW with this style HUD. I likely would have selected it if it was an available option on my build order.
