2.0t not charging battery
jlrusoin
Sean
Indiana
Jeep JL Rubicon
Have a 2019 JLRU 2.0t. The battery is not charging. Just installed a new suspension with a lot of welding, battery was unhooked while welding. The battery will hold a charge but the voltage drops while driving. Found fuse F75 blown. To troubleshoot should the alternator be putting out 14+ volts read at the battery when idling if not what voltage should it be? What could be causing the no charging issue? Thanks.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Do you have ESS (start-stop) on your Jeep? If so the Aux battery may be bad and is pulling your main battery down with it! I believe the alternator gives 14+ when driving.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Voltage when idling is like 12.5-13ish. When driving it should sit around 14.4. The OEM batteries are absolute crap though and most likely your aux or even both have a bad cell and should be replaced.
Long arm kit install?
jonyothan
Jon
Ontario, Canada
'22 Rubicon 2dr 2.0T, '10 335i, '03 Golf TDI
HD Mechanic
mine is always around 13.5-14.4V with engine running. sounds like the voltage regulator in your alternator may be faulty
jlrusoin
jlrusoin
Sean
Indiana
Jeep JL Rubicon
Thanks. Idling or at higher rpm’s the voltage is the same as it is not running so definitely an issue. Battery is now a Optima yellow top.
Yes just installed the EVO long arms.
RAO
Ray
NC
2015 JKU Sahara; 2022 JL Rubicon; 2025 Sahara
With the eTorque you don’t have a standard alternator but a starter/generator. Thats the bad news. The good news is that it may still be under warranty. You may want to look into that.
jlrusoin
jlrusoin
Sean
Indiana
Jeep JL Rubicon
Here's one option. I don't know what you consider to be expensive, so I'm just passing on the link as an FYI. ?
This is what my Jeep calls for. List price $914 but found it for $602
GENERATOR KIT, MOTOR GENERATOR UNIT. Engine.
Part Number: 68432441AC
Supersession(s): 05185014AB; 05185014AC; 05185014AD; 05185014AE; 68432441AA; 68432441AB; 68432441AD
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
Because it's part of the etorque system and considered part of an emmissions device, like the etorque batter is, it may be covered under the same party of the warranty. I believe it's 80k miles (I forget the time, but at least 5 years) Worth a shot. That generator is expensive.
Maverick909
I.E.
www.instagram.com
this should be warranty i agree with the rest of the members here.
