2.0 coolant top off frequency
Gregj
Greg
West Texas
I have the bottle and I’m waiting on the hose connector. The hose has a thick insulation but the connector is exposed. I think it’s getting too hot so I’m going to try and insulate it more since it’s right next to the turbo. I’m also wondering if it’s just the o-ring at the connector going bad. If we only had to replace the o-ring every once in awhile it would be cheaper.
Curious as to how long the hose has been on order? Hope mine ships quickly.
Gregj
azjl#3
North AZ
I check the fluids in all of my vehicles every Saturday morning. Possibly it's a good habit to adopt, for those owners who don't currently have one.
Great excuse fellas to tell the honey you really have to do something right now...
Heimkehr
Pennsylvania
2021 JLU 2.0T
Boss Lady was complaining of a strange smell on start up. I crawled under it to look at the coolant neck that is the subject of many leaks and nope, not it! I did find pink liquid on the upper control arm on the drivers side. I traced it up to the coolant bottle, leaking at the fitting on the bottom.
Ordered the bottle and the hose from @allmoparparts $106.00 plus shipping.
Gregj
There are two coolant reservoirs on/for my 2.0T: an opaque, pressurized oval tank adjacent to the master cylinder, and a small round translucent reservoir (for the intercooler) adjacent to the washer fluid bottle.
For future reference, which "coolant bottle" had the leak on your Jeep? P/Ns for the reservoir and hose would be appreciated, too. Thanks!
Gregj
Greg
West Texas
Boss Lady’s Jeep has e-Torque so it has three. The one that is leaking is the black one between the turbo and the brake booster. Here are the parts I ordered. Waiting on confirmation from Allmoparparts.
Jeep Wrangler JL 2.0 coolant top off frequency 2195167A-4085-4872-BCA3-15BD50EA8D01
Gregj
Swany
Rod
Omaha
2018 Wrangler JL
I am having the same issue (2018 JL 2.0 turbo) of needing to add coolant. But my issue seems to be with the auxiliary coolant pump (and/or hoses) for the Turbo, on the passenger side. Anyone else having this issue?
Jeep Wrangler JL 2.0 coolant top off frequency IMG_1503 2
Jeep Wrangler JL 2.0 coolant top off frequency IMG_1499
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
So 2 months ago on Oct 6 this was the level. I don’t remember if it was dry at one point but I vaguely remember fiddling with the dipstick. Topped it off then to the max line. I’m hoping it’s just that it had to flow through the system or something and make its way through the rest of it.
Jeep Wrangler JL 2.0 coolant top off frequency IMG_1358
December 7 last week before a roadtrip. Gonna check the coolant level after work today since it’s been about 1.2k miles since topping it off before the trip. But the water pump looks like it never leaked from there, but I haven’t checked the reservoir itself yet.
Jeep Wrangler JL 2.0 coolant top off frequency IMG_4109
Jeep Wrangler JL 2.0 coolant top off frequency IMG_4112
Missed the hole a little(that’s what she said)
Buster1
Ft Worth, TX
‘51 M38
Low coolant again. 8k miles since the last top off, and just added 8-10 more oz! I can’t see any signs of leaks.
WI_Sarge
WI
2024 wrangler sport S
Similar issue. My intercooler reservoir is fine and stays at the max line. My engine coolant reservoir seems to deplete. 24 sport s, with only 1700 miles. Ive had to fill it twice already. Im no mechanic, but looked every where with a Flashlight and see no signs of leaking or dried up coolant at connections. Ive never done an oil analysis but might have to do that next time. Im also gonna make sure its documented at the dealer for any future problems they might to get out of.
any other recommendations or things to check the average idiot can do?
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
Good ideas. I think you’re on top of it doing that.
WI_Sarge
WI
Does anyone have a pic of the waterpump from below? Trying to find someway for me to locate and check but not sure exactly what it looks like.
thanks in advance
Heimkehr
Pennsylvania
2021 JLU 2.0T
Not sure if this will help. It's the graphic taken from TSB 07-001-22 REV. A, regarding the water pump inlet tube fasteners. If these fasteners aren't correctly torqued, coolant will slowly leak from them.
Jeep Wrangler JL 2.0 coolant top off frequency Water pump Inlet Tube Fasteners
WI_Sarge
WI
I did locate it, but everything looked normal
WI_Sarge
WI
Those are a pain to get to. They felt very snug, although I don’t know the exact tightness. Thanks much for the tips though. I just 80 miles and did a visual above and from below and didn’t see any signs of coolant. I didn’t notice any particular smells. Once the car cools off, Ill check the levels again.
