roaniecowpony
I will have to disagree here, having grenaded an engine from hydraulic lock.Pretty sure that's obvious. But I doubt OP had a hydro lock. As soon as your engine sucks in the water it's over, you don't drive on for a mile or half a mile or even a hundred feet. It locks up pretty much instantly.
What happened in my case, was that the engine, a 2.0L turbo running 30+ psi boost) blew a head gasket after shifting to 2nd gear at Orange County drag strip. I detected a slight power loss, but turned in a good time/ET. When I let off the throttle, it sucked in water from the coolant jackets. Friends observed steam upon letoff. This damaged the connecting rod. But it wasn't obvious. I replaced the head gasket, oil, coolant, etc. Then took it for a drive down the street. Everything was normal. First time it came up on boost, the rod went through the side.
