1310 or 1350?
icebrrrg
Matthew
Lehigh Valley PA
2024 JLR, 1994 YJ
Shop is ordering an RK lift it for me along with a new front driveshaft. They want to know if my U-joint in the front is a 1310 or 1350. I honestly don’t know. I recall reading that they had remove the front axle delete from 2024 forward. I don’t have access to a shop manual.
I have a 2024 two-door JLR, basically stock except for some armor upgrades. Does anyone know is the factory U-joint is a 1310 or 1350, from the front differential to the driveshaft?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You sure they aren't asking which one you want? IIRC, it's a plate/flange bolted on at the diff in front, you replace the original joint.
If it's one or the other it's definitely not a 1350.
GATORB8
CLT NC
factory is rzeppa (CV) joint, not u-joint. I think they're asking you which one you want to buy
RZeppa is at the case, there's a single U-Joint at the front diff on the stock shaft.
Jeep Wrangler JL 1310 or 1350? 1753729632194-xs
Maverick909
I.E.
1350 all day
icebrrrg
icebrrrg
Matthew
Lehigh Valley PA
2024 JLR, 1994 YJ
Thanks all. Most of my personal experience with this stuff is with my YJ so I feel under-researched for the JLR.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
The factory joint is a 1330. I would upgrade to the 1350.
Ford is the only manufacturer to use the 1330. Jeeps use a 1310.
And yeah, it's a flange on the axle. Easy to bolt up a 1350 in its place.
icebrrrg
icebrrrg
Matthew
Lehigh Valley PA
2024 JLR, 1994 YJ
Yeah, turns out this is what they were asking. I am going with the 1350. Thanks again, all!
JT1
Broken Arrow, OK
2021 Willys Gladiator
How much lift are you installing and what is the extended length of the front shocks?
If you don't have a FAD, and you want 6* of caster or so up front, a 1350 joint will probably give you vibrations. The 1310 has a larger window of happy.
If your shocks aren't 28" or longer, don't replace your driveshaft, spend the money elsewhere.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
This is the way. AEV 2.5 lift with all the flex I need for the rocks. Shocks aren’t over 27” so no need to replace the stock shaft. I still had room left to go if I wanted on the ramp.
Jeep Wrangler JL 1310 or 1350? IMG_1054
Jeep Wrangler JL 1310 or 1350? IMG_1056
  • Like
Reactions: JT1
