1 inch lift options?
RubiCube5
Leopold
Tampa
Jeep Wrangler Unlimited Rubicon
Hey everyone, I really like how 35's look on the 392 and was wondering since my JLUR is 1 inch shorter than a stock 392, what's the best way to get the additional 1 inch to get the same stance? Or point me in the direction of a thread on this topic?
I considered a few 2-inch lifts kits out there but 35's look small in my opinion. I also don't want to go 37 just yet. I use the Jeep for daily commute and weekend overlanding with friends and family. Thanks!
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Synergy has 1” springs. I think that’s the only place from when I was researching a couple of months ago. I bought their rear 1” JLU springs due to carrying weight out back on trips.
rts4714
Ryan
Charlotte
2020 JLU Sport S
Is the lift 1in shorter or the whole ride? If the whole ride is, the 35s will give you that 1in difference
Stock rubi tires are 32.7in (K02s)
AnnDee4444
'18 JLR 2.0
FYI: Synergy's springs recommend a 2" bump stop on their 1" lift springs. https://www.synergymfg.com/synergy-jeep-jl-jlu-rear-lift-coil-springs.html
OP: 1" spacers are definitely the easiest way to get exactly 1". Changing springs can be +/- depending on your options & weight, but 392 springs might get you close if you have an aftermarket front bumper and/or winch.
RubiCube5
RubiCube5
Leopold
Tampa
AnnDee4444
'18 JLR 2.0
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
I personally don’t need them as I’m not going to bottom out stock Rubicon shocks or destroy a fender. Does fine flexed and there is no bottoming out of the stock shocks. Also, with my load, I lose about 3/4” of that lift. CBC is good to go too.
If one went with longer shocks, sure, follow the directions clearly laid out on their site.
Jolly’s Jp
Kevin
NC
2021 JLUR on 37s
I put a 1” spacer up front for the time being until I figure out what I really want to do. I keep leaning towards 35s instead of 37s as well.
So far from my research, Eibach makes springs that are 1” front and .6” back. Other then that, Clayton is supposed to be coming out with a 1.5” kit towards end of summer.
