XY600A pin out
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
Dealer bent my pins and one broke. I need a diagram with the pin out whatever male connectors, I would need. Maybe a source for , all the different size pin and the connector. It would be the chassis side. Grrrr
Pramod
Pramod
India
Rubicon
Please look at the Full Repair Kit for this connector: 68500854AA
I am attaching the connector details here, hope this helps you.
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
I'm not sure what pins you're talking about, but if the dealer bent it then the dealer should be fixing it, right?
You’d think that but I’ve never had luck with that sort of thing. They bent it but how do I prove it.
2nd 392
Ca
If you don’t catch dealer damage before you leave You could have done it after you left. Yes— that is a quote. ~1 1/2” Black paint scrape to the primer hidden with black grease. Got home and washed the greasy mess they made and discovered it, immediately went back and reported the damage. The quote was the response. I Never blackened that dealer’s doors again. ? Still give it a shot, there are some reputable dealers. You will find out if yours is one of them with the response. Good luck.
Deleted member 59498
Guest
They were taking your doors off? Isn't that the plug?
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
Can i just buy the connectors both male and female and crimp and do it myself. And not the 250 kit of pigtails
Pramod
Pramod
India
Rubicon
Yes, you can. You should check the connectivity once you are done.
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
Where can I buy them from? Just the terminals. I’ll get my on wiring
